Help! smoke problem
Like Tree2Likes
Old 12 May 2014, 08:48 pm
Exclamation Help! smoke problem
I have 03 pt gt,the car runs but it pours out white smoke for the exhaust, iv checked oil,an looks fine,the car does have random miss fire but from valve cover seals leaking oil on plugs. but really thinking its the turbo going out, turbo spolls,but no boost gage to see boost lost or not,not trying to drive car until problem found. some body help me out,new to turbos,next step if cant find problem is to get rid of car.
Old 12 May 2014, 08:56 pm
Default Re: Help! smoke problem
Need more info on the milage and so on. Pull off pcv hose and block off on the intake side. See what that does. Not a sweet smell is it?
Old 12 May 2014, 09:03 pm
about 68 thousand miles. dosent smoke until fully warm,smoke even comes from valve cover holes fittings,what ever you call them. it has a smell like burnt or boiling smell,the car does not over heat.some times the coolent boils. an could having oil on the plugs have any effect with the problem.
Old 12 May 2014, 09:17 pm
Starting to sound like coolant not oil. Been adding antifreeze?
Old 12 May 2014, 09:25 pm
I have it running on straight water,want to flush system trying to find the right coolent for it,an the pvc dosent have a hose on it,it that bad? just hoping its not the turbo,i know its not the head, or head gasket. I dint drive it much,an stoped after it started smoking, don't have a lot of money to drop all around the motor on parts.
Old 12 May 2014, 09:39 pm
You just answered the problem. Smells like boiling water. Same on the rear tailpipe.?
Old 12 May 2014, 09:45 pm
lol,never checked, ill check it tomorrow.
does the pcv valve need a hose,or is it okay with out it?
would the coolent stop it from boiling? or the coolent would boil also,coolent getting put in as soon as possible.
what coolent should be used?
Old 12 May 2014, 09:57 pm
A good 5yr coolant. And stay with the same kind. Some will say hoat. But As long as you use one product and don't mix with other brands It's all good. Use distilled water to keep from building mineral deposits in the block and head.
Old 12 May 2014, 10:20 pm
thanks,i will update about the car after coolent,an gaskets been replaced.
hopefully the car should perform as it should,an boost gage will be added soon.
Old 12 May 2014, 10:30 pm
2step's Avatar
In the turbo there is a shaft that connects the intake/compressor side to the exhaust/ impeller side. That shaft has an oil lubed bearing and some seals that can leak oil into the exhaust and out the tailpipe when they fail. You might notice that the "smoke" is slightly blue-ish if it's oil and a more pure white if it's coolant. The difference is very subtle, though, and hard to tell. Maybe you can check right after a drive for residue at the tailpipe to see if it's wet or oily.
Why is the hose missing for the PCV system? Is the fitting on the back of the intake manifold plugged or capped where the hose is supposed to connect? Because if it isn't, you have a massive boost/vacuum leak. The PCV valve could be stuck open, acting as a breather or it could be stuck shut dumping oil vapors into your air box and intake, pre-turbo. The hose piece is $5 and 5 minutes to replace. It sounds to me like maintenance has been pretty spotty so It would probably be a good idea to get a new PCV valve while you're at it.
Fog light problem with smoke mattiow Tech & Performance Forum 7 15 Jan 2013 01:23 pm
Help!!! smoke and belt problem webstertroy General PT Cruiser Discussions 5 28 Sep 2012 06:33 pm
200,000 Miles and now she wants to smoke? Teknoron67 General PT Cruiser Discussions 23 13 Aug 2012 04:15 pm
HO LEE SMOKE! Cal Cruzer Stage Turbo Kits 18 28 May 2005 03:18 pm
