2004 2.4L Turbo-Clutch problem
Like Tree5Likes
  • 2 Post By randyincctx
  • 2 Post By UptownSport
  • 1 Post By rob342
Old 21 May 2014, 09:40 am
Default 2004 2.4L Turbo-Clutch problem
Hello, I am new to this site, but I have been doing a lot of reading about transmission, and clutch problems so I can help diagnose what's wrong with my cruiser. A couple of weeks ago, my clutch just went....it left me stranded on the side of the road....it would go into each gear but the clutch wouldn't pull at all....nothing...so I took it to a local mechanic, and he seemed to be clueless on PT Cruisers....first he said I needed a new clutch, he kept ordering the wrong part...just a regular clutch and flywheel....but my cruiser has the dual flywheel....(I am a girl..so bare with me if my terminology is incorrect) After sending the wrong part back 2x he said I would need to get the clutch with dual flywheel.....my budget is low so I told him to just go ahead with the new clutch....and use the original dual mask .......all of that was 500.00 including labor....when I picked my car up....it wasn't right...I couldn't barley get it into gear....if I pumped the clutch it would work better...so I drove it a few days hoping it would get better, but it only got worse....I took it back to him, he said I should have gotten the whole assembly....There is a popping sound when I engage my clutch....I think its the master clutch cylinder....its popping loose not allowing my clutch to fully engage.....when I put it back in place my car runs smooth....so my question is...do you agree that I need to replace my entire clutch system again with a new dual mask flywheel? or just the master cylinder for the clutch? Thanks so much for any suggestions....
Old 21 May 2014, 03:25 pm
randyincctx's Avatar
Lightbulb Re: 2004 2.4L Turbo-Clutch problem
That sounds like the clutch master cylinder wasn't bled right.......
Try to get a look at where the master cylinder/clutch pedal assembly mounts to the firewall.......A member posted an issue similar to what your describing,and it turned out to be the metal had cracked where the upper bolt mounts to the firewall,and 'popped' whenever the pedal was pushed in.
I don't remember if they posted an update on how(or if) it ended up being repaired.
Here's the area of the firewall you should be looking at in this photo:
PT_Firewall.jpgThis is from a PT w/ATX,so there is only the metal coverplate(2 bolts) showing,on a PT w/MTX the clutch pedal gets bolted on the interior,and the master cylinder is bolted to the exterior.
UptownSport and rob342 like this.
Aka:~KILLER~
Old 24 May 2014, 09:24 am
UptownSport's Avatar
Default Re: 2004 2.4L Turbo-Clutch problem
^^^ Good memory
rob342 and randyincctx like this.
Old 25 May 2014, 09:00 am
bad memory here, but good with google searching the forum: Firewall splitting on 05 Dream Cruiser
randyincctx likes this.
2004 Turbo possible ECM problem...looking for suggestions brentrw General Turbo Discussions 0 02 Mar 2013 06:07 pm
2004 PT GT Turbo shaking problem cbohlson Tech & Performance Forum 10 01 Aug 2012 03:03 pm
2004 Turbo PT Mode Door Problem Slope General PT Cruiser Discussions 3 05 Sep 2009 08:20 pm
2004 turbo edition pt cruiser problem tbocruiser Tech & Performance Forum 1 06 Mar 2009 02:41 am
Clutch Problem Mean Green General Turbo Discussions 8 16 Nov 2003 11:52 pm
