Changing the turbo
Old 07 Jun 2014, 01:21 pm
Default Changing the turbo
Hello, all!
My daughter's 2005 GT Turbo made a loud screech, then ran poorly. Dealer found three error codes and said turbo is shot. Wants 4500.00 to replace it. I have the car back home, and found aftermarket turbo for 350.00 in the internet.
Car has 79k miles, otherwise in good shape.
What would be a reasonable cost to replace the turbo, and is it a DIY project? I have all the tools necessary but have never done this type of repair.
Thanks!
Old 07 Jun 2014, 01:37 pm
Default Re: Changing the turbo
It is a pretty easy DIY replacement if you have some experience working around engine and tight access.
You could also try to rebuild your TURBO yourself. Danny aka Busted_PT has a great DIY thread on how to do it.
Rebuilding the Turbo!
DOING ANOTHER TURBO
Turbo
Busted_PT likes this.
Old 07 Jun 2014, 02:45 pm
DOING ANOTHER TURBO
Turbo
On page 17 is some of the highlights of the turbo install and precautions I saw when doing mine. Busted_PT project 1
Old 08 Jun 2014, 10:47 am
vipergts's Avatar
Originally Posted by Homee2010 View Post
Hello, all!
Thanks!
What do you mean aftermarket? You do not want to go with anything but an stock OEM turbo for your situation!
E1 Turbo, 3 Bar Map~Tip, 888/1025cc Duster's Injectors, Stage 1 PCM, Composite Intake Manifold, Airbox Mod With Drop In, Ported Exhaust Manifold, Walbro 255, 3 Inch Catless, Poly Mounts, Blue Plate, DCR Oil Mod, DSP, AEM A/F, FM WGA, N2mb Electronic Boost Controller, Power Demon ATX, Duster's CMR Tune, E85 Powered, Cross Driiled Rotors, BTG Springs, Mopar Ground Effects Kit, 5K HID lights and fogs, LED Tails...3080 lbs in race trim.300WHP~345 Ft Lbs Torque @ 16PSI...Now boosting 19PSI, WHP And Torque numbers coming soon.
Old 08 Jun 2014, 10:51 am
vipergts's Avatar
You need this: Neon SRT 4 PT Cruiser GT TD04LR Turbo 03 05 Stock Factory turbocharger SRT4 | eBay
Old 08 Jun 2014, 07:43 pm
vipergts's Avatar
If you don't want to tackle it yourself, any decent garage should replace it for 500$ or so...
Old 08 Jun 2014, 08:19 pm
Be sure and determine why the turbo died - you should replace the oil lines and be sure and use synthetic oil.
Old 12 Jun 2014, 08:17 am
vipergts's Avatar
I think Homey was using us
Old 12 Jun 2014, 09:18 am
Sometimes all they want is their problem fixed and their gone. Often without any follow up on the outcome. Just part of this type of forum.
Old 14 Jun 2014, 08:07 pm
vipergts's Avatar
Ya' What a D~bag
changing turbo from stock! pocketpcaddict General Turbo Discussions 10 20 Apr 2011 12:22 pm
Changing battery in '06 GT Turbo CruzinGT General Turbo Discussions 6 08 Sep 2010 06:36 pm
changing plugs on 2005 turbo dbcruiser General Turbo Discussions 7 10 Jul 2010 01:25 am
Question about changing oil on a 2.4 turbo mfh6375 Tech & Performance Forum 10 31 Dec 2008 10:48 am
Changing front springs on a 2006 non-turbo samson77 Wheels, Tires, Suspension 2 10 Feb 2007 07:12 pm
