Need help.
Like Tree2Likes
  • 2 Post By Feiery
Old 08 Jun 2014, 02:07 am
Feiery's Avatar
Default Need help.
I have a 2006 PT Cruiser GT Conv.
Whenever I start up the car, a plume of white smoke comes out of the tailpipe. Fortunately, it doesn't continue to billow out. But the reason is because there is oil in the intake manifold. Also, the car stumbles on acceleration at times. I'm thinking this is in part due to oil getting in the air. What I need to know is what is causing this.
Gregg
2006 PT Cruiser GT Convertible
Old 08 Jun 2014, 02:54 am
Feiery's Avatar
Default Re: Need help.
I did find a possible solution:
Massive oil consumption/HUGE cloud of white smoke on start up
I need to have the PCV valve looked at. I'm going to try that first and see what happens.
Gregg
Old 09 Jun 2014, 10:24 am
Feiery's Avatar
The PCV valve was the culprit. The mechanic had to remove the valve cover to get the pieces of it that fell inside.
Gregg
Old 09 Jun 2014, 10:52 am
Luckaly it didn't do any damage to the engine when it fell apart. Glad you got it fixed.
Old 09 Jun 2014, 11:42 am
You were indeed lucky. Every other possible cause of your problem would be way more expensive to fix.
Old 09 Jun 2014, 12:19 pm
The pieces would have stayed in the baffle of the cover. This happens a lot. But I like knowing there out also. Glad you have it sorted out.
Old 13 Jun 2014, 12:13 am
Feiery's Avatar
Talking Re: Need help.
Thank you. You and me both.
Gregg
Old 13 Jun 2014, 11:42 am
2step's Avatar
The PCV valve is a maintenance item and needs to be changed from time to time. Not as often as an oil change but more often than a spark plug change.
