I NEED HELP!! PLEASE! ANYONE!
Like Tree3Likes
Old 08 Jun 2014, 12:30 pm
Exclamation I NEED HELP!! PLEASE! ANYONE!
I HAVE A PT CRUISER THAT STARTED TO SMOKE BIG CLOUDS OF WHITE SMOKE! I LOOKED UNDERNEATH AND FOUND OIL IN MY EXHAUST. I OPENED EVERYTHING UP AND THERE WAS OIL EVERYWHERE IN MY VALVE COVER, VACUUM HOSES, AIR FILTER LIKE LITERALLY EVERY! I HEARD IT CAN BE MY TURBO BUT I TOOK OUT SPARK PLUGS AND 3 OUT 4 SPARKS PLUGS WERE DRENCHED IN OIL ON THE BOTTOM OF THE PLUGS WHERE THEY SCREW IN NOT ON TOP WHERE PORCELAIN IS BUT THEY SPARKED AND CAR STARTED AND RAN FINE FOR MOST PART. RAN COMPRESSION TEST AND THEY WERE ALL PRETTY CLOSE. I"M WONDERING IF TURBO CAN CAUSE ALL OF THIS??? PLEASE HELP ANYONE! ANY TIP CAN HELP RIGHT NOW! THANK YOU!
Old 08 Jun 2014, 12:51 pm
boonie2's Avatar
Default Re: I NEED HELP!! PLEASE! ANYONE!
Year , Make , Model ???
2004 Pt Cruiser 2.4 L {non turbo} 113K miles , Electric Blue pearl {PICTURES in my Profile Album}
Full Synthetic Oil 10w30 K&N Filter
Full Synthetic Trans Fluid / filter Change :bolt-away
Old 08 Jun 2014, 01:11 pm
Its a 03 Chysler Pt cruiser 2.4L turbo
Old 14 Jul 2014, 04:56 pm
Dream Cruiser, GT, or Limited? Just curious.
Old 14 Jul 2014, 05:20 pm
cruserdad1976's Avatar
no the turbo can not cause oil to be covering the entire engin yes it can cause smoke
first check your PCV valvue to make sure it is intack and working
if your plugs are oily on the threads on one the electrode im not sure what is up
i cant even think of anything that would cover the motor in oil
maybe power wash the engin and then start it and let it run while checking it out??? dont knwo is it drippijng oil onto the ground??? was it low on oil?????
Old 14 Jul 2014, 08:15 pm
chris15's Avatar
Not sure why the year, make or model matter since in the OP's first post he references a PT Cruiser and mentions having a turbo. The trim doesn't matter either.
OP:
- As Cruiserdad mentioned, I would replace the PCV valve.
- You can wind up with oil in the intercooler pipes, throttle body and intake manifold if you have a blown seal in the turbo.
- You mention having oil "in" the valve cover. Well, there needs to be oil in the valve cover to lubricate the cams..
- Oil can exit the system through the hose on the driver's side of the block that leads to the airbox. There's a little sponge-like filter in the airbox that's intended to "catch" this stuff. Replace that (typically found in the Help section of most parts stores), and your regular air filter.
- If your spark plugs have oil on them, you need to replace the valve cover gasket.. specifically the 4 spark plug o-rings that are included in the set. Honestly unsure of how you could end up with oil in the exhaust as it would burn out in the combustion chambers and exit the system as blue smoke.
Start there and see if your issues resolve themselves.
2003 GT (6262, the works)
2001 PT MTX-Swapped/Turbo
Old 14 Jul 2014, 09:12 pm
randyincctx's Avatar
Cool Re: I NEED HELP!! PLEASE! ANYONE!
What he said....
Aka:~KILLER~
Old 15 Jul 2014, 09:28 am
but the op said the oil was NOT on the porclin part of the plugs Ok so I really have no idea if the plugs were soaked in oil on the electrode they would not fire or fire reallyl baddly
Old 15 Jul 2014, 09:47 am
The oil doesn't have to be all the way u on the porcelain of the plugs for the I rings being bad. But still can run down the threads as you take them out. If you bounce them around the hole you could get oil on the electrode. Hard to tell really. Whatever is putting oil all over the engine has nothing to do with oil in the exhaust. The op hasn't been back since the first 2 posts?
Old 15 Jul 2014, 11:06 am
i noitced that
