PT Throwing Error Codes
Old 16 Jun 2014, 12:43 am
Default PT Throwing Error Codes
Hey my name is Sam, I have a 03' PT GT and i've always had a steady check engine light on with code P1188 on since i bought the car. Recently it's been throwing out a P0522 error code as well. Anyone know the causes or have any possible solutions?
P1188 EOT Sensor Ckt. High Voltage
P0522 Engine Oil Pressure Sensor/Switch Circuit Low Voltage
Old 16 Jun 2014, 05:19 am
Default Re: PT Throwing Error Codes
Lots of problems with that sensor. Change it and be done with that code.
Old 16 Jun 2014, 08:31 am
not a very efficient way to change it in this how to, but you can see the sensor on the engine:
HOW TO: oil pressure sensor replacement
Old 16 Jun 2014, 11:50 am
Thanks guys I'll probably take it to my familys local mechanic and see how much it would be to replace the sensor. Hopefully replacing this will be the end of it ^^,
One thing though I'm trying to find the unit online right now for purchase would it just be called the oil pressure switch or is it called oil pressure sensor?
Old 16 Jun 2014, 12:09 pm
You might try here?
Factory Mopar Parts - OEM Auto Parts
Old 01 Nov 2014, 09:20 am
CREWZIN! You make things so simple! I was expecting to read through about 5 or 10 pages of a forum topic, but no, here you are saying "just do this".
Thank you so much! I will order the part right now and post an update as soon as I replace it... and drive it for about 100-200 miles.
2003 PT Cruiser Turbo - ~96,000 Miles
Bought it in March 2010 with 49K miles.
DIY Work: Put in a K&N Cold Air Intake Kit the year I bought it. Brakes, upper and lower engine mounts (struts) replaced. Knock sensor replaced. Camshaft position sensor replaced.
Mechanic work: Replaced the timing belt at 90K miles. Replaced the engine at 95K miles (stripped spark plug hole, even the heli coil stripped after a week).
Old 01 Nov 2014, 12:02 pm
soonercruiser's Avatar
Red face Re: PT Throwing Error Codes
Yup!
2 of my 4 PTs have had the oil sensor replaced.
Frank, aka SOONERCRUISER,
2011 GWE Dodge Challenger SRT8 as Show Car
Old 17 Dec 2014, 12:00 pm
So you guys helped me with the smoking issues and problem solved, however after I was done took for a test drive and ran the sh** out of it! the chk engine light came on , took to local shop and he said it was turbo over boost! said to drive normally and should be ok! well it came back on again! what should I do it has a new turbo on it?
Old 27 Dec 2014, 01:10 pm
I have an 1188 code and a. PO234 have no value whoa they are or where they are?mplease help
Old 27 Dec 2014, 01:28 pm
LionPT's Avatar
They are both Turbo Boost codes, other than that...I can't help.
I'm throwing some codes sleepy General Turbo Discussions 1 29 Sep 2012 10:14 pm
Error Codes Error lilcruiser Tech & Performance Forum 2 10 May 2012 05:34 am
Error codes hidinginparadise Tech & Performance Forum 2 23 Jan 2012 08:52 am
Error Codes bucksfan1976 General Turbo Discussions 0 22 Feb 2011 01:03 pm
error codes??? Turboguy85 Turbo Performance 2 22 Sep 2010 05:15 pm
