MY Poor Cruiser!!
  • 1 Post By quicksilverdon
Old 19 Jun 2014, 09:08 pm
Unhappy MY Poor Cruiser!!
Alright guys, I have a dilemma. My 06 Cruiser is overheating when it is idling. I can turn the heater on and it doesn't overheat anymore but I live in Texas and the heat is already bad enough without adding to it. If I don't turn my heater on my coolant bubbles like there is tomorrow when I turn the engine off. What could this be? My dad is out of town or I would ask him! I really didn't want my first post to be on a bad note
Old 19 Jun 2014, 09:16 pm
Default Re: MY Poor Cruiser!!
Welcome to the forum.
The most probable cause is that your radiator fan isn't working. There are other things that could cause overheating but the inoperable fan is something we find most often. Do you know if the fan is working?
What kind of mileage do you have? Do you do your own maintenance or have it done somewhere?
Old 19 Jun 2014, 11:25 pm
I have my maintenance done at the Dodge dealership. The last time I checked the radiator fan was working. it had 125,000 miles on it. I have only had it since March and only put like 10,000 miles on it because of work.
Old 20 Jun 2014, 09:13 am
The fan is the most likely candidate as Crewzin mentioned.
Old 20 Jun 2014, 09:22 am
cruserdad1976's Avatar
didnt say7 if it wa a turbo but if its not i agree order a fan from ebay and put it in before you kill the motor
Old 20 Jun 2014, 10:01 am
Until you get it fixed, be sure you have enough liquid in it - use distilled water - you can get it at supermarket for steam irons - when car is cold - hasn't been run for hours, take off radiator cap and fill it to the brim, then add to overflow bottle on passenger side firewall.
Be sure radiator cap is seated well when you are done.
2step likes this.
Old 20 Jun 2014, 10:53 am
2step's Avatar
Start with the simple things first before you start replacing fans. The bubbling sound is indicative of low coolant and/or loss of pressure in the system, usually from a failed radiator cap. Top off the radiator like Don suggested (you may have to top off again a second cool down cycle) and then, if the "bubbling" continues, replace the radiator cap. To avoid scalding yourself, be very sure to only top off or replace the cap when the system has cooled down. Also look for leaks on the ground and report back here if you have any. Note that it's normal for A/C system to drip water in the area by the firewall, passenger side. A coolant leak will probably be near the front but can possibly be farther back on occasion.
Old 20 Jun 2014, 02:14 pm
I know where you are, I'm down the road from you
Old 20 Jun 2014, 03:17 pm
harrym's Avatar
Welcome to the forum from SW Missouri.
As others have said, check coolant levels first. BUT NOT WHEN HOT! Make sure it hasn't been running for a while.
Harry
2005 Touring n/a - Cool Vanilla with J&J vertical billet grille, PTeazer tail lights, Chrome wheels and Baby Moons.
Tags
2006, overheating, touring edition
poor pt jrbsr05pt General PT Cruiser Discussions 9 04 Apr 2012 10:04 pm
Poor mpg AspenMeadowRanch Tech & Performance Forum 30 22 May 2011 03:58 pm
MY POOR PT 2k1PT Tech & Performance Forum 10 22 Aug 2008 02:24 pm
Oh my, poor PT! JolieCruiser General PT Cruiser Discussions 9 27 Apr 2008 09:47 pm
Poor PT :( ucantcme General PT Cruiser Discussions 21 20 Mar 2008 03:08 pm
