Alright, I did do a search to see what people are using to get the stains off of the front of the manifold. Didn't find anything. It's starting to bug me now [xx(] [:0]
Is this what you're looking for.
http://www.ptcruiserlinks.com/forum/...Terms=manifold |
What exactly did you do a search on?
![]() Same way with mine...Im thinking Ill just powdecoat it gunmetal
![]() 14.67 @ 94.5 <--- Self Proclaimed Fastest East Coast PT with Black wheels!!! |
\'05 Stone White SRT4 \'04 Graphite PT Automatic |
So is it agreed that so far we think this is just normal road grime which for whatever reason seeks the manifold??
06 GT Auto, Cool Vanila Exterior, Presto Change O 3bl, Cargo Mat and Net, Billet Oil Cap, Yoko Avid 4Vs Tires, 03 GT Wheels, 4 Chrome Door Handle Screw Covers, MOPAR Mud Flaps, H&R Rear Sway Bar, Freedom Strut Tower Bar, Rear Door Sill Covers. |
I like the powdercoating idea
![]() Gunmetal I have the discoloration also. Interesting thing is that when I removed and replaced the gasket when I installed S1, the gasket was clean and dry. That manifold should have only air running through it. UNless the cast aluminum is porous enough to allow oil vapor to settle in the only area that has turbulence along the track. Kinda like with endocarditis: bacteria settle around a valve leaflet because of turbulence that allows it to settle. Especially when it is generated by an abnormal valve (MVP, bicuspid aortic valve, floppy chorda tendinae). maybe it's the same thing with oil vapors along the gasket seal and have diffusion of oil along the interface between the gasket and manifold and then settles along the base of the runners. Or, everything I said is complete bullsh-t[ ]
![]() 2003 GT Inferno Red,5-spd,Eibach Springs,Koni Sport Adjustables, Eibach front and rear Sway Bars, Mopar Stage 1,Mopar BOV,Custom 2.5\" Dual Tip Exhaust (Magnaflow),Hurst Short Throw Shifter, Pioneer DEH6500 Headunit, RF Punch 300 and 301 Amps,RF 12\" Sub and MB Quart Reference and Premium Speakers,Ronal RT 17x7.5\'s with Michelin Pilot Sport 225/45ZR17s, Koni Adjustible shocks, Keystone single scoop, GT Airraid Intake, Mopar Ground Effects Homepage: http://www.cardomain.com/id/ptgtredman http://blueman.ptenthusiasts.net/index.html |
I just looked at mine. I am NOT happy. 5800 miles. Yes,,, there are "stains" from the gasket area upwards. It is definitly oil stains, just scrape off the front of the manifold bolts,,, with your finger, this is not road grime.
After examining the entire manifold joint area I see that "there just ain't enuff boltz". Try to imagine a mere 10 lbs of boost in there... ( ya can do this by trying to blow into a boost gauge with your mouth and havin someone look at it from da front,,,if ya get 3 pounds, your lucky) this is a HUGE amount of pressure in that plenum. Now boost it up to 16 lbs. I'm sorry, but this area is going to leak with the factory supplied bolt pattern. "There just ain't enuff boltz." Add that to over 60 mph + speeds ,,, it blows back up onto the manifold. IMHO, I believe that we have oil blow by in the turbo seals causeing this problem. That's the only place it could come from. My Stage 1 kit is on the way. I anticipate installing it the 15th of May (or so). I will be scrutinizing the entire manifold, as i want to port match it all and maybe polish it up a little, while I have it apart. My 2 centz George C. Thomas
03 GT PT, Inferno Red w/factory flames, AutoStick, Stage 1, Mopar BOV, BTG duals, Airaid, 5 HP fuzzy dice |
Used Goo Gone to clean it up and it looks nice again.[?]
| Turbo plastic manifold on N/A PT? | littleblueGT | Tech & Performance Forum | 4 | 24 Jan 2007 01:05 pm |
| Plastic manifold & plugs | quicksilverdon | General Turbo Discussions | 3 | 21 Mar 2006 12:48 pm |
| PLASTIC GT MANIFOLD PROBLEMS? | littleblueGT | Turbo Performance | 27 | 28 Oct 2005 10:14 pm |
| Turbo manifold question | proxeyed | Tech & Performance Forum | 6 | 29 Jan 2005 12:55 am |
| Torque question for intake manifold on a GT | crazie.eddie | Tech & Performance Forum | 5 | 29 Oct 2004 04:00 am |
