noticed a "ticking" noise
Old 21 Apr 2004, 10:46 pm
Default noticed a "ticking" noise
Last night, a noticeable ticking noise was detected coming from under the hood. It wasn't the typical sound you hear from the fan running, but more like a lifter/tappet or a small exhaust leak. The dealership said the noise was a common problem on the turbo motors and I was wondering if this was true. Has anyone who owns an '03 GT Turbo experienced this?
Thanks for any responses that may help...
J.
Old 22 Apr 2004, 12:33 am
Welcome to the forum, jsp70.
I experienced this problem with my 2003 Inferno Red GT. [:0] Read about the SAGA of the "mysterious" turbo engine noise here: http://www.ptcruiserlinks.com/forum/...?TOPIC_ID=3426
Old 22 Apr 2004, 12:30 pm
No ticking noise here @ 13,000 miles. That sounds like the dealership's "I'm to freakin' stupid and don't care about you go screw yourself unless you can bring your car in here for something I can charge you full retail for" standard answer. Hope there are other dealers in your area. Although they all seem to be trained with this response.
Old 22 Apr 2004, 05:49 pm
mine does it. Has since new. I notice no ill effects from it so far. And I did say, So far[8D]
Old 23 Apr 2004, 11:15 am
I've had that sound since new also, some are of the opinion that it comes from poorly adjusted lash adjusters.
So far I can't see any problems from it, to be honest i am afraid to let them wrench on the motor at the dealer.
It is a distressing problem for sure, on one hand I'm not sure if letting it go will cause problems down the road, on the other hand I feel more trouble will come of the repair.
I don't really have the time to fight back and forth with a dealer on this kind of thing, I need this car every day.
[:I]
PianT
Old 23 Apr 2004, 11:28 am
Welcome to the forum jsp70!
2002 Inferno Red PT Limited
Mercedes Wiki
Old 23 Apr 2004, 01:12 pm
My 03 Turbo did this too. Dealer replaced the cam bearing caps. That fixed it.
NUMBER: 09-007-04
GROUP: Engine
DATE: March 2, 2004
This bulletin is supplied as technical information only and is not an authorization for repair. No part of this publication may be reproduced, stored in a retreival system,
or transmitted, in any form or by any means, electronic, mechanical, photocopying, or otherwise, without written permission of DaimlerChrysler Corporation.
SUBJECT:
Irregular Engine Snapping Sound
OVERVIEW:
This bulletin involves chamfering the bore radius on cam bearing caps
L2 through L5 and R2 through R5.
MODELS:
2001 - 2004 (JR) Sebring Convertible/Sebring Sedan/Stratus Sedan
2002 - 2004 (KJ) Liberty
2002 - 2004 (KJ) Cherokee (International Markets)
2003 - 2004 (PL) Neon
2001 - 2004 (PT) PT Cruiser
2001 - 2004 (RG) Chrysler Voyager (International Markets)
2001 - 2004 (RS) Town & Country/ Caravan/Voyager
2003 - 2004 (TJ) Wrangler
NOTE: This bulletin applies to vehicles equipped with a 2.0L, 2.4L DOHC or 2.4L
Turbo engine (sales code ECC, EDZ, ED1, EDV, ED2 or EDT).
SYMPTOM/CONDITION:
The sound may be noticed when the engine is idling in park between idle rpm and 1400
rpm at normal operating temperature. The sound is on the upper end of the engine
(cylinder head) towards the front of the engine or passenger side (right side). The sound is
irregular, not periodic or harmonious. The frequency of the sound will increase with RPM.
The sound is more of a higher pitch snapping noise not a low metallic knock.
DIAGNOSIS:
If the vehicle operator describes the Symptom/Condition and the technician determines
that the sound is from the upper end of the engine (cylinder head) towards the front of
the engine or passenger side (right side), perform the Repair Procedure.
09-007-04 -2-
REPAIR PROCEDURE:
1. Remove the cylinder head cover (Refer to information available in TechCONNECT
9 - ENGINE/CYLINDER HEAD COVER - Removal)
2. Remove L2 cam bearing cap (Fig. 1).
NOTE: Do not remove the #L1/R1 or L6 cam bearing caps, or loosen the fasteners.
NOTE: Only remove one cam bearing cap at a time.
Fig. 1 CAMSHAFT BEARING CAP IDENTIFICATION
3. Lightly chamfer the two bore radius edges with a small hand file, creating a 45 chamfer
1.0 to 1.5 mm in width along the edge of each bore radius (Fig. 2).
CAUTION: Be careful not to scratch bore surface of cam bearing
cap. Chamfer both bore radius.
Fig. 2 CAMSHAFT BEARING CAP
1 - CAM BEARING CAP RADIUS
4. Clean part to remove any aluminum filings prior to reinstalling.
-3- 09-007-04
5. Reinstall L2 cam bearing cap by loosely assembling fasteners. Prior to and during the
torquing of each fastener, twist the cam bearing cap by hand in a clockwise direction,
as viewed from the top of the engine. Torque M6 fasteners to 12 N·m (105 in. lbs.)
while maintaining a clockwise twisting force on the cam bearing cap.
6. Repeat steps 2 through 4 for cam bearing caps L3, L4, L5, R2, R3, R4, R5 and R6.
POLICY:
Reimbursable within the provisions of the warranty.
TIME ALLOWANCE:
Labor Operation
No:
FAILURE CODE:
52 Improperly Machined
Old 23 Apr 2004, 02:42 pm
wsd0836,
Did they replace the bearing caps or "hand file" them as described in your post?
PianT
Old 23 Apr 2004, 05:49 pm
Well...I was told that they were replaced. But who really knows. It was a warranty repair so the details of how it was fixed were not on the paperwork I received.
noise from frontend Hotrod Tech & Performance Forum 9 19 Mar 2010 06:39 pm
"Mysterious" turbo engine noise...??? Gary04GT Turbo Performance 76 21 Aug 2006 08:28 am
Got my S1 today! boosta Stage Turbo Kits 18 28 Dec 2004 07:36 pm
Road noise / exhaust noise in the car. jackatg450 Tech & Performance Forum 3 21 Jul 2004 10:55 pm
acceleration and decceleration popping noise Art Rigby Tech & Performance Forum 1 06 Oct 2003 02:30 pm
