My GT overheated. Very strange.
Old 23 Apr 2004, 05:05 pm
Default My GT overheated. Very strange.
This happened to me last sunday. I drove around on the highway for about 30 minutes. Windows were rolled up and I had the cool air blowing. Not the A/C and not the heater, just cool air. I then drove around for another 30 minutes in the city through local streets, still with the cool air blowing. Then all of a sudden, the temp. light blinked and the needle was in the red hot zone.
I pulled over right away, shut the car off and popped the hood. I noticed that even though the car was off, the anti-freeze tank was shaking. Don't know if this is normal or not.
Anyway, I waited about 5 minutes and decided to keep driving my car to my destination which was only a few blocks away. When I started the car again, everything was fine. The temperature needle stayed in the middle (where it always is) and I haven't had this problem since.
I'm not a mechanic and don't know anything about cars. Any idea why this happened? This probably sounds stupid but could it be that since I was blowing cool air inside (not A/C), I was taking the cool air away from the engine and therefore it overheated? I don't know. I'm just trying to find out if I should bring the PT in for service or just let it go for now.
Thanks in advance.
Old 23 Apr 2004, 05:10 pm
Wonder if you have a stuck thermostat.
Check the lines under the car for dampness or if there is any leak.
just a thought.
Thermostat housing is to the left of the radiator, just below the radiator coolant cap.
Homepage:
Old 23 Apr 2004, 08:47 pm
This was probably as a result of the coolant still boiling into the overflow tank, which can tend to make them shake.
Sounds odd though. How many miles are on the car? Is this a NA or a Turbo? Ever have the water pump or thermostat replaced? If so, there could be air trapped in the block. If not, check for small spots of coolant under the engine near the water pump and/or thermostat.
\"They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety.\"
Benjamin Franklin, Historical Review of Pennsylvania, 1759
www.cybermopar.com
TripleJack
Old 24 Apr 2004, 12:19 am
Do a search, I believe there is a bulletin on this. Either a flash or PCM replacement!
Old 24 Apr 2004, 04:01 am
I think what you may find is that the fan quit working and caused the overheating and when you restarted the fan came back to life. Probably some kind of electrical problem!
Old 24 Apr 2004, 02:37 pm
Exactly what the problem was/is, try this post;
http://www.ptcruiserlinks.com/forum/...ms=overheating
Old 25 Apr 2004, 02:36 am
Mine is a Turbo with 7600 miles. Never had any problems or anything replaced.
It hasn't happened again so I'm not going to bring it in for service but I'm keeping an eye on this. At least I know that some PTs are having this problem and that the there is a PCM fix for it.
Thanks guys.
Old 29 Apr 2004, 05:21 pm
yep, mine has done this 3 times in the last month Did it again today. It's always after shutting off my A/C. Looks like service appt is in order[xx(] I sure hope they have a fix for a S1 PCM with this problem.
Old 30 Apr 2004, 02:41 am
Send a message via AIM to spicy pt
Have a friend who has a turbo and had this same problem. Ended up being that the fan quit working. Definitely have it checked out before it happens again...and the outcome is an engine fire. [V]
\'03 DreamCruiser #1040, too many interior and exterior chrome accents to list, orange/white underbody neons, SPICY PT 3BL and plate
Old 30 Apr 2004, 01:20 pm
Send a message via AIM to yobiebs
I had something similar happen when I had under 5000 miles on mine. turns out that there wasn't enough coolant in the engine. May want to check your fluid levels. Can't hurt....
2003 Electric Blue GT
The Philadelphia Flyer
Modelling a PTGT but ratio looks strange arrow1234 General PT Cruiser Discussions 12 09 Mar 2007 09:51 pm
Strange Miss fire nuke72 General Turbo Discussions 12 22 Feb 2006 07:04 pm
need advice on strange electrical problem in Jeep comPuTer General PT Cruiser Discussions 1 07 Jul 2004 07:31 pm
Strange email from Bolivia skylight General PT Cruiser Discussions 21 21 Dec 2003 10:19 pm
A strange request nbr10 General Turbo Discussions 7 05 Nov 2003 05:33 pm
