High Engine Idle and NO CODES
Like Tree2Likes
Old 20 Sep 2014, 09:35 am
Default High Engine Idle and NO CODES
I have a 2003 PT Dream Cruiser which I had parked a few months ago. When I went to drive it all sorts of codes were being thrown. Apparently critters got the frame rail harness which cleared many codes. Replaced MAP, TIP, O2, wheel speed sensors and all codes cleared. The only problem that remains is the fact that the engine idles at about 1400 to 1600 rpm and will not go lower. I checked for codes again but nothing. By the way the code checker wasn't one of the home ones, it was a high end SnapOn unit that he uses for his business ( he is a truck mechanic, does cars for friends)
What could this be? I miss my Dream Cruiser and need to get it back on the road.
Old 20 Sep 2014, 10:38 am
Default Re: High Engine Idle and NO CODES
It sounds like one of the critters took a bite out of one of the vacuum hoses. Any leak of vacuum will cause the idle to raise. Check all the rubber vacuum hoses that you can find.
rob342 likes this.
Old 20 Sep 2014, 10:40 am
LionPT's Avatar
Clean or replace the IAC.
Old 20 Sep 2014, 10:53 am
i'd guess crewzin has the right idea. i have had a plethora of problems caused by critter chewing this year. i dont see why they wouldn't chew a vacuum line, seeing they did this to my cap:
Old 20 Sep 2014, 01:06 pm
Thank you for all the quick help. Didn't think of the vacuum lines. I think the IAC was cleaned or replaced but will double check. I am amazed at what trouble little critters can cause.
I love my dream cruiser. Its only stock but so much fun to drive.
Old 20 Sep 2014, 01:46 pm
Could a problem with the PCM be causing the high idle? My mechanic friend checked for vacuum issues and IAC was replaced. Just weird because no DTC's to indicate the problem.
Old 20 Sep 2014, 02:10 pm
It's always a possibility but highly unlikely. Did you check the throttle cable on top of the engine for free play or binding of the cable? One thing you might try is taking off the negative battery cable for 5 minutes. Step on the brake while the cable is off, then re-attach everything to see if that resets the computer faults. Can't hurt.
Old 20 Sep 2014, 02:31 pm
Will check. I did notice that one of the throttle cables did seem loose. I will definitely do the battery reset as well. Thanks as always.
Old 20 Sep 2014, 06:15 pm
don't overlook the obvious. make sure the throttle body is closing all the way.
Old 20 Sep 2014, 09:35 pm
soonercruiser's Avatar
Talking Re: High Engine Idle and NO CODES
Ahhh......my specialty!
Two parallel and prominent incisors!
Considering the size....MICE!
Should have the young-ins see their dentist if they are "teething" on your Cruiser!
Frank, aka SOONERCRUISER,
05 PT Cruiser Error Codes & Idles high GA81PEACH19 Tech & Performance Forum 5 06 May 2013 10:41 pm
High idle 2001cruising Tech & Performance Forum 17 12 Sep 2012 09:17 am
Codes, codes, codes... Desperately need engine light help... cdc3jj General PT Cruiser Discussions 9 01 Sep 2012 07:52 am
High Idle and Cooling issues shadowsnkx Tech & Performance Forum 0 06 Sep 2011 08:55 pm
2003 MT High Idle Sturdevant General Turbo Discussions 6 11 Sep 2007 09:55 pm
