03dream cruiser problems
  • 1 Post By jabili1979
Old 05 Nov 2014, 02:49 pm
Default 03dream cruiser problems
Hello PT cruiser fans. The PT has always been one of my favorite cars growing up, now that I own one as cool as it is it has been a bit of a struggle to keep reliable. We purchased a 2003 dream cruiser series 2 on craigslist, the car came from Arizona and the bodywork is beautiful no rot. The car is a 2.4 liter turbo with 4 speed automatic with autostick. The car now has 115,300 miles on it, and had 3 owners before me.
Now for the problem, I'll try to keep it short. A few months ago during the summer during inspection the mechanic said he had a problem with the A/C which he said he fixed for us. Also we believe that the heater core is leaking but we haven't gotten to fixing that yet. In the hot summer after stopping at a gas station my car didn't start right away. At first we thought the battery had died, we waited a minute and started right back up no problems. But now it seems to be a constant problem. It seems when the car heats up to the halfway point, after shutting it off and leaving it, the car will stall and buck and misfire. We've gotten a lot of codes out of it. We have tried multiple solutions. Such as replacing the cam position sensor and the crankshaft sensor. We have replaced the O rings on the fuel injectors. We have replaced both the input and output speed sensors, we have cleaned the throttle body. The previous owner had the computer replaced so we seem to think. We have tried many solutions but we still get the same problem. Stalling, engine bucking and sometimes the car won't start at all. We are thinking it could possibly be the computer, the ignition switch or maybe a faulty wire or connection. Hope somebody can help.
One other note- if we put on the a/c the engine idle will change and eventually stall the engine.
Old 05 Nov 2014, 03:10 pm
Default Re: 03dream cruiser problems
Welcome to the forums.
a few things to try while you wait for the real guru's.
1 do a compression test, could be a dying piston / piston rings / head gasket
2 Pull the Ac harness off, so the clutch wont engage, could be a seizing clutch.
3 i see you replaced a few things, but have you tried just a simple tune up? Plugs,wires, air filter, Possibly coil pack *test it first*
cheers
Old 05 Nov 2014, 04:10 pm
We need the codes you speak of. I would have the battery load tested. Simply because the heat really kills them in Ar. So I've been told. Be good to rule out low voltage. Once we get the codes we can offer better answers.
Old 05 Nov 2014, 05:26 pm
Ok s the codes we've gotten we know what they all mean but, they are
315, 325,300, 301,302,303,304,201,202,203,204,480,582,586, 594
The more recent codes are 480, 582, 586 these are the ones that I've gotten over the past few weeks I haven't seen a lot of the other ones for a long time. But we have them all written down so I figured I'd list them all.
Old 05 Nov 2014, 05:37 pm
Uhm... i would not drive it in that condition.
codes 301 - 304 and 201-204 Make me wanna say timing belt jump.
Then i see 315 and 325. Failed sensor? <--- where i would start.
Then there is 480 -Low speed on the cooling fan malfunction.
Old 05 Nov 2014, 05:38 pm
as you stated in the original topic, why was the AC serviced?
Old 05 Nov 2014, 06:07 pm
cheers
Agree with these thoughts, particularly plugs & wires - can't hurt...
Old 05 Nov 2014, 08:11 pm
p0315, p0325,300, 301,302,303,304,p0201,202,203,204,480,582,586,p059 4
The more recent codes are p0480, p0582, p0586 these are the ones that I've gotten over the past few weeks I haven't seen a lot of the other ones for a long time. But we have them all written down so I figured I'd list them all.
Well I don't think a tun up is going to have much effect on these codes. I'm thinking wiring to these items. Maybe even vacuum leaks on the last two codes. IDN
Old 05 Nov 2014, 09:52 pm
I would suggest you might have two separate problems.
I would suggest fixing your coolant leak. You should not be driving the PT Cruiser with an unsealed coolant system. You will have a potential headgasket problem. You should check your radiator fan to make sure its working properly.
2nd suggestion is to see if your cruise control is not working I would check your vacuum solenoid and speed control vent solenoid. You might want to check all the wires going to both solenoids. Check all vacuum hoses.
Old 06 Nov 2014, 01:09 am
cruserdad1976's Avatar
id clear everything and see what comes back
2003 PT Cruiser Cruiser AC Problems PTCruisers Tech & Performance Forum 12 23 May 2015 12:43 pm
Another Cruiser with A/C problems MyBestFriend Tech & Performance Forum 2 23 Jun 2014 05:26 am
New old Cruiser - problems, problems problems pt_papa General PT Cruiser Discussions 7 23 May 2014 04:13 pm
new cruiser with a few little problems...! roz84 Tech & Performance Forum 5 12 Feb 2012 12:35 pm
Problems with my cruiser morrisbeer General PT Cruiser Discussions 3 25 Apr 2009 07:52 pm
