turbo spooling noise with muffler delete
Old 01 Dec 2014, 11:54 am
Default turbo spooling noise with muffler delete
I recently purchased a 2004 limited turbo with 65k . The original owner removed the muffler and put a 30-31 inch glass pack (brand unknown) in the center tunnel. On acceleration (not floored) there is a turbo spooling noise which my mechanic says is accentuated by the exhaust modification. Since i have no idea how old the glass pack is i wonder if removing it and putting a new magna flow or thrush would help. No noise on cruising no matter what speed.
Any suggestions would be great.
Old 01 Dec 2014, 12:08 pm
Default Re: turbo spooling noise with muffler delete
Do you have a stock intake? Those so called cold air intakes will make the turbo noise louder. Ask NotroPT he is running a glasspak muffler.
Old 01 Dec 2014, 12:22 pm
stock intake and the sound is mostly coming from the muffler area not the engine compartment
Old 01 Dec 2014, 12:33 pm
So im confused, you dont want the sound? you want to quiet it down or are u asking if the noise is normal??
Purple 2005 PT GT ATX w/ Mopar stage 1 PCM, Diablosport 93 oct tune, airbox mod, K&N drop in filter, Mopar BOV, AGP wastegate (8 psi spring), Custom made stage 1 camshafts, motor mount inserts, NGK Iridium plugs, MSD wires, ARP Head Studs, Gates Racing Timing Belt, AC Delete kit, purple painted Valve cover, Rebuilt (stock) Turbo , AEM Boost, Oil Pressure, and Wideband guages, triple guage A pillar pod, Strut Tower brace, Needswings 3in o2 housing, 3in downpipe w/ high flow cat and electric cutout, 2.5in Magnaflow catback, custom check valve, custom larger capacity trans cooler w/ built in cooling fan, Eibachs pro lowering springs, KYP front and rear struts, matte black hood and grille, gloss black stock SRT neon rims, purple lug nuts, blacked out tailights and reflectors so far. Built and bored out motor, AGP S256 turbo, ported cylinder head, and built trans soon to come.
Old 01 Dec 2014, 12:36 pm
Have you inspected it? The turbo and cat converter usually damp noise enough so that noise is acceptable even with a poor muffler. If it's split, that'd do it...
Old 01 Dec 2014, 01:32 pm
Let me clarify - I don't mind loud exhausts ( long time harley rider and presently an owner of a jeep gc srt8 with a borla atak exhaust). Its the accentuated turbo noise overlaying the exhaust. My original feeling is that the muffler had broken down over time and the packing ( maybe steel) was flying around inside during acceleration. Hence the thought that changing out the muffler would help
Old 01 Dec 2014, 01:41 pm
Changing the muffler MAY well help. We're just trying to assist you making the decision...
Old 01 Dec 2014, 02:19 pm
and i thank each and every one of you for your input
Old 01 Dec 2014, 02:30 pm
Glass pack burn out . The materiel does not stay in the case when that happens.
Your description is still a bit hard to get what you are trying to achieve? The Turbo does not go into boost during normal cruising and the average psi for normal during is about 3-6 psi. Naturally if you are are a bit more aggressive with the throttle the Turbo whine will be loader. Most of the Turbo noise is usually from modified intake parts. The CAT will tend to muffle most all the exhaust noise before it gets to the muffler no matter what choice of muffler is used.
Below is a our 05 GT with stock exhaust manifold and CAT with a Cherry Bomb Glass Pack and no tail pipe section. You can hear from the video that it is not load.
At idle with a "gurgle" file uploaded via the DST
You can the Turbo starting to go into boost at 1.22 seconds into the video
Old 02 Dec 2014, 11:18 am
Thanks for the info. However, none of the videos play. The screen just goes white
2005 PT With Muffler Delete TeamTFR PT Cruiser Videos 0 16 Feb 2013 11:38 pm
Muffler delete sleepy General Turbo Discussions 14 15 Dec 2012 06:27 pm
Non Spooling Turbo DREDAWG10 Turbo Performance 3 06 Oct 2011 12:13 pm
Muffler Delete Pipe NavyCruiser Tech & Performance Forum 7 05 May 2011 07:40 pm
Turbo Muffler ??? SFsGT03 General Turbo Discussions 6 19 May 2004 08:07 am
