'05 GT will not pass CA smog Readiness
  • 1 Post By NitroPT
Old 12 Dec 2014, 04:10 pm
Thumbs down '05 GT will not pass CA smog Readiness
Howdy,
I have a '05 GT with 120K. Car runs like a champ and I am going to sell her right after I pass smog (already got another car). Problem is I had the timing belt replaced which resulted in disconnecting the battery to do the work a few months back.
I cannot get the Catalyst and Oxygen sensors to go to Ready to even start up the SMOG test. This has been going on for almost 3 months and I go back to see if it can pass every weekend. Dealer and another shop said to just keep driving it.
Driven 860+ miles freeway and city.
No codes at all.
Runs like a top
Tried different brands of gas (premium)
Replaced the front O2 sensor last week as a hail mary.
Just got back and I have these results. Can someone help me interpret them?
Bank 1 Short term fuel trim 0.0%
Bank 1 Long term fuel trim 17.2%
Bank 1 sensor 1 O2 output volts 0.115V
Bank 1 sensor1 short term fuel trim 0.8%
Bank 1 sensor 2 02 output volts 0.055V
bank1 sensor2 short term fuel trim 99.2%
So the big problem looks to be bank1 sensor 2 is out of whack. It should be in the single digits so my air fuel mixture is way out of whack right? What is my next step? Look for vacuum leaks, replace something?
Any help would be greatly appreciated!
Old 12 Dec 2014, 04:33 pm
Handy_Cruiser's Avatar
Default Re: '05 GT will not pass CA smog Readiness
Wait just a moment and my cyber-stocker will follow me to this thread and tell you how to deal with this. Your problem is one he actually knows about first hand with a PT Cruiser. So it's good advice.
And in the mean time, here's a link. You can contact him by PM if he doesn't take the bait.
California SMOG Testing the NITRO way
Old 15 Dec 2014, 12:24 am
Looking into this further, +99% looks like I am running lean.
I found this:
Running too lean High positive fuel corrections can be traced to MAF and O2 sensor faults, vacuum leaks from intake gaskets/hoses, unmetered air (intake snorkel leak), clogged or dirty fuel injectors, fuel delivery issues, and exhaust restrictions such as a clogged catalytic converter.
Any ideas?
Old 15 Dec 2014, 01:17 am
I would suggest checking out the other Oxygen Sensor after the catalytic converter. I am surprised you are not getting any engine trouble codes.
I would also suggest checking the wires on both Oxygen Sensors.
Have you been using engine oil for a long time?
Old 15 Dec 2014, 09:29 am
I believe you are looking at Mode 6 data. Its very hard to find any information on Mode 6 data.
Old 21 Dec 2014, 12:24 am
Thanks for the suggestions. I will try replacing the downstream O2 sensor next weekend and checking the wires. I'm stumped too with no codes showing up.
Sorry for the late reply, the storms knocked out my internet but I am back now.
Old 21 Dec 2014, 12:51 am
If you want a legal way to pass and you are at your limit of allowable faults in the readiness file with no,engine light then pm me .
Handy_Cruiser likes this.
Old 21 Dec 2014, 08:20 pm
Also its a good idea to purchase OME electrical parts. sensors, ETC. If you haven't already.Many on this forum have stated this information.
Tags
smog
OBD II readiness test failed - no codes crzypt Tech & Performance Forum 28 26 May 2019 07:23 pm
2004 5spd turbo wont pass smog? jrunner Tech & Performance Forum 6 10 Aug 2015 06:29 pm
Has anyone familed smog? R_I_PT Tech & Performance Forum 0 22 Nov 2011 06:43 pm
OBD MONITOR READINESS STATUS CRUSAIR PT Cruiser Convertible Forum 10 06 Oct 2010 06:55 pm
Stage 1 Did not Pass California Smog Test nitrouspt Stage Turbo Kits 5 28 Oct 2009 09:16 pm
