Motor sound Vibration
Like Tree3Likes
  • 2 Post By CREWZIN
  • 1 Post By soonercruiser
Old 19 Dec 2014, 06:03 am
Smile Motor sound Vibration
Hi my friends, the question or situation I have with my PT is 2005 turbo dream cruiser conv., I have a vibration in drive or park change you the 3 engine mount that could be?
Than you...
Old 19 Dec 2014, 08:01 am
Default Re: Motor sound Vibration
WHAT? Sounds like Yoda talking. I think your asking if all 3 motor mounts should be changed. You can easily check at least two of the mounts to see if the rubber inserts have deteriorated. Here's a couple You Tube video's to show you how to check or replace the mounts.
quicksilverdon and Laranapr like this.
Old 19 Dec 2014, 01:59 pm
soonercruiser's Avatar
Cool Re: Motor sound Vibration
If it were the motor mounts, you might even get a little "clunk" when you put the tranny in "Drive", or start up from being stopped.
Had that on mine last fall.
Laranapr likes this.
Frank, aka SOONERCRUISER,
Old 20 Dec 2014, 09:49 am
Thumbs up Re: Motor sound Vibration
My PT is well up to to change it time bell that will lead it to a mechanic and the saw the lower bad mout and change it and from there started the vibration and thinking that the other should be bad also changed him but vibration remains the only missing is the transmission, thank you for the videos
Old 31 Dec 2014, 01:16 am
The real mount is the one in the frame rail on the passenger side. You can keep changing the upper and lower torque arms 'til you're broke, but until you replace the middle one, you're wasting time and money.
Mine was really bad, but there was no clunking, and the vibration was just annoying, not that bad. And an expensive job, I can see why many people sell their car rather than pay for it.
Old 31 Dec 2014, 01:28 am
Old 31 Dec 2014, 01:31 am
When you replace the upper and lower torque mounts there are some that are not aware of the factory alignment procedure that must be done after the torque mounts are replaced. Without the alignment procedure being completed there is a good possibility of vibration issues.
Old 22 Mar 2015, 12:02 am
And my question is how can align them the 2 mounts, videos I've seen only speak to simple .you would like to know how I can do it properly... thank you
Old 22 Mar 2015, 12:28 am
You are useing an Internet translator
Can someone post either in the Haynes, Chilton or better yet the Factory Service Manual the proper way to instal and align the engine mounts.
Sorry I am on the IPad and don't have access to my FSM files and pictures.
Those old video's are "lame"!
Looking To Replace Either Fan Motor Or Fix Motor If Possible - Anybody BTDTGTBT... scoleman69 Tech & Performance Forum 8 22 Dec 2013 05:33 pm
Motor Mounts Replaced Now Vibration at Idle falconut Tech & Performance Forum 12 15 Mar 2013 07:48 pm
Vibration at 70 mph Brunoka Tech & Performance Forum 5 19 Jun 2012 07:36 am
Vehicle vibration and knocking sound over bumps MauiPT Wheels, Tires, Suspension 1 25 Feb 2011 06:42 pm
Vibration!!!! 2003ptcrusierbrusier Tech & Performance Forum 8 05 Jan 2004 08:45 pm
