03 Coolant Issue
Old 16 Jan 2015, 09:46 pm
Default 03 Coolant Issue
I have a 2003 PT GT that is leaking coolant from somewhere on the backside of the motor. It's been leaking for a while but the level in the reservoir hasn't dropped and I'm unable to see exactly where it may be coming from. It's possibly the hard lines that run from the heater core that T off to the turbo but I'm unable to tell. It gets worse if it boosts, if I go somewhere and keep the boost gauge at 0 or lower it usually won't leak. Does anyone have any ideas of what it could be? The car is supposed to have a somewhat recently rebuilt head with new head gasket.
Old 17 Jan 2015, 10:59 am
Default Re: 03 Coolant Issue
With the engine completely cold, open the radiator cap and look in - is coolant up to the brim? It needs to be.
If you're leaking and overflow level stays the same, it means the tube to overflow has a leak as well and radiator can't suck from overflow bottle.
Is temp gauge at halfway?
Old 17 Jan 2015, 12:22 pm
I've had to add coolant to the radiator a couple times. The tube going to the reservoir doesn't have any leaks.
Last night it coated most of the stuff between the airbox and turbo with an oil and coolant mixture and the temp went up to about 3/4 on the gauge. I bled the cooling system, topped up the radiator, and drained the reservoir to where it should be. Ran it alittle today and no leak and it didn't go above half on the temp gauge but there's more fluid everywhere. Still can't find where any of it is coming from
Old 17 Jan 2015, 12:47 pm
At most service stations (the kind that does more than pump gas) they have a pump that is attached where the radiator cap goes. They can pump the system up with air that will force coolant out of the tiniest cracks. Stop by a place and see if they will do it for you.
Old 17 Jan 2015, 12:48 pm
That sounds like your original guess:
"It's possibly the hard lines that run from the heater core that T off to the turbo but I'm unable to tell".
Don't see that causing overheating - look at oil dipstick and oil filler cap after car has been run - any sign of brown foam??? Engine fan working?
Old 17 Jan 2015, 01:00 pm
The fan is working properly and no foam in the oil or any signs of anything head gasket related. I'm taking it somewhere tonight to get the system checked.
Old 17 Jan 2015, 01:30 pm
Might check the coolant where it goes to oil filter. That has been a leak as well.
Old 17 Jan 2015, 01:57 pm
I rented a pressure tester and have it at 18psi right now and there aren't any leaks
Old 17 Jan 2015, 06:49 pm
I would suggest checking the coolant pipe feeding into the heater core. Sometimes they have a thin crack lines that are hard to see.
Old 17 Jan 2015, 10:17 pm
Turns out that the locating pin on the thermostat came out and got stuck sideways in the spring in the thermostat and it got stuck halfway open. New thermostat is in and no problems yet
Waterpump / Coolant / Heater Core Issue? No Heat... rhino169 General PT Cruiser Discussions 40 12 Sep 2017 12:23 pm
Leaking coolant - "Engine coolant pipes"? xkey General PT Cruiser Discussions 3 01 Jun 2014 09:11 am
massive oil/coolant issue jamestown478 Tech & Performance Forum 16 10 Dec 2013 06:52 am
Troubleshoot coolant leak: Photo of Coolant on top of engine radiator cap MarcusO Tech & Performance Forum 7 27 Apr 2013 09:16 am
Best Coolant For a 03 PT?? tcr1016 General PT Cruiser Discussions 4 27 Nov 2010 09:01 pm
