Codes
Old 26 Jan 2015, 12:49 am
Default Codes
Just bought my 03 turbo two days ago. So far, I love it! The check engine light just came on and I got the codes p0335,p0340,p0344.I know what they are. I'm pretty short on money right now. My question is :is it ok to drive with these codes showing for a couple of weeks?
Old 26 Jan 2015, 01:05 am
Default Re: Codes
I would suggest unplugging the sensors, make sure good contacts, and then put them back on. Make sure the wirings is good and not rubbing against the motor somewhere. Reset the engine trouble codes with the OBDII Scan Tool and see if they come back again. Wouldn't cost anything to do that.
Old 26 Jan 2015, 01:14 am
Default Re: Codes
Thanks, forgot the other code 0522. The oil light is on. Everything looks good. Is it ok to drive?
Old 26 Jan 2015, 01:47 am
Default Re: Codes
Did all of these engine trouble codes come up at the same time?
Old 26 Jan 2015, 03:15 am
Default Re: Codes
Yep! Right after it spitted and spudered going down the highway.
Old 26 Jan 2015, 09:33 am
Default Re: Codes
I would suggest confirming you have adequate oil pressure before driving it anywhere. Did you check the oil level? Do you have a friend that has a OBDII Scan Tool so you can reset the engine trouble codes?
I would suggest that you check to see if the Crankshaft Sensor, Cam sensor or Oil Pressure sensor is shorting to ground effecting your PCM. You might want to check the wires on all three sensors to see if they are rubbing against the motor or melting together. If all looks good then you might need to have your PCM checked out.
The most important goal here is to make sure you have adequate oil pressure. Its possible that someone told the previous owner that sold the PT Cruiser to you that it needed a PCM and going to cost $$$$$ so the previous owner decided to sell it instead.
Need help with codes TommyBlazin Tech & Performance Forum 5 02 Apr 2014 04:07 pm
Dash codes--not the usual OBD codes--help! chitowncruiser General PT Cruiser Discussions 5 01 Mar 2013 11:56 pm
Codes, codes, codes... Desperately need engine light help... cdc3jj General PT Cruiser Discussions 9 01 Sep 2012 07:52 am
CODES codes codes... Anyone know what these codes may mean are wrong? rksnow1 Tech & Performance Forum 10 16 Jun 2012 11:06 pm
TOO MANY CODES!!! Nonie Tech & Performance Forum 13 20 Mar 2011 12:21 am
