False error codes
  • 1 Post By ptcruisersteve
Old 21 Feb 2015, 03:10 pm
coastalshooter's Avatar
Default False error codes
My 2004 turbo pt is throwing false error codes. I've had everything from all dashboard things stop working to backfiring happening and once I reset computer - it runs like a beast...until the next code(s) shows up. I'm not sure what could be causing this but am hoping it is some sort of sensor instead of the whole computer needing replaced. Any feedback on what it might be would be greatly appreciated as I'm lost!
Old 21 Feb 2015, 04:08 pm
Default Re: False error codes
I would suggest checking your battery and battery cables. Make sure the battery cables are clean and making good contact. The PT Cruisers are very sensitive to voltage drops.
If battery voltage is good and cables are good then have a battery load test done.
You also might want to introduce yourself to the forum so others can get to know you and details about your PT Cruiser.
Old 21 Feb 2015, 06:15 pm
Agree w/Steve. Problem is electrical. PTs do not behave well with low voltages - either from weak battery or connections.
Old 27 Feb 2015, 09:38 pm
Thank you for the advice and your time. I haven't had a chance to act on the advice yet but appreciate having a place to start ...and that it might not be the cpm is great news!
Old 27 Feb 2015, 10:34 pm
I would also suggest checking the battery fluid levels. On one of my PT Cruisers I check it every two months and fill as necessary.
Tags
false codes, turbocharger
Error codes Lilwolf68 Tech & Performance Forum 3 03 Apr 2014 01:27 pm
Error codes: Luvour04ptgt Turbo Performance 3 25 Aug 2013 09:16 pm
Error Codes Error lilcruiser Tech & Performance Forum 2 10 May 2012 05:34 am
Error Codes bucksfan1976 General Turbo Discussions 0 22 Feb 2011 01:03 pm
Error codes mr.troy Tech & Performance Forum 3 16 Jan 2007 04:26 pm
