sudden very loud turbo whine
Like Tree7Likes
Old 28 Feb 2015, 03:24 pm
Kev Kev is offline
Default sudden very loud turbo whine
Hello all, I have a 2005 signature series, that has an "intermittent" problem where it will run very rough and jump and shake like the cylinders are being randomly fired and would throw the mapp sensor code, it also occasionally throws the non-specific misfire code. (I forget the actual numbers). In attempting to resolve this problem by checking the usual culprits the turbo suddenly out of the blue developed this extremely loud whine which can be heard a block away. It now throws the P2074 code but the original Mapp code seems to have cleared however the problem of running very rough at idle remains.
My question, is this coincidence that my turbo failed while troubleshooting the rough running issue or is there anything external to the turbo I may have messed up that could cause this severe whine?
Any and all suggestions and guidance would be deeply appreciated.
Old 28 Feb 2015, 05:09 pm
Default Re: sudden very loud turbo whine
I think you have a hose blow off. The turbo gets loud it the hose gets off.
Old 28 Feb 2015, 08:35 pm
soonercruiser's Avatar
Cool Re: sudden very loud turbo whine
On my 2005 Dream Cruiser Convertible, I've always had a small background whine....less so afer she warms up. I have eliminated everything except a small boost leak.
Yours could be a BIG BOOST LEAK!
That might have percipitated some codes.
Frank, aka SOONERCRUISER,
2011 GWE Dodge Challenger SRT8 as Show Car
Old 01 Mar 2015, 11:21 am
Kev Kev is offline
Thanks guys, I checked the three tiny vac lines off the turbo and a 4th larger one, all seem to be tight.
I removed the big air intake line from the filter box and carefully looked into the turbo, there seems to be no play in/out or laterally. The vanes look good and I can spin the turbo with my finger.
Oddly, it does not whine/howl near as bad revving in neutral as it does when accelerating during a test drive. Something has definitely changed since I started working on it, it is extremely loud and in the past the only time I ever heard the turbo was when it was spooling down after shutting the motor off.
Could it be that it is not getting any oil? and is there an easy way to confirm it is?
Could a faulty waste gate or that other actuator (whatever it is) be causing excessive noise?
I would hate to replace the entire turbo only to find it wasn't the problem. It seems like a monstrous job and cost to replace,
Thanks again.
Old 01 Mar 2015, 11:36 am
How is the power? A big boost leak should make your car slower.
Check the big hoses to/from intercooler.
Old 01 Mar 2015, 01:48 pm
Thanks again.
You can pull the oil lines and inspect them.
Some do get clogged.
Old 01 Mar 2015, 02:32 pm
Kev Kev is offline
Really appreciate the help guys, I'll check the intercooler lines and the oil lines once I figure out which line is what.
Read thru Busted PT's turbo rebuild and still digesting all the info, by the way B-PT, that is one of the best "how to" instructions I have ever read, great photos and concise step by step comments. Two thumbs way up! Mind you I pray I don't have to use them.
Busted_PT likes this.
Old 04 Mar 2015, 12:50 pm
Kev Kev is offline
Looks like I'm rebuilding or buying a new turbo, can not find any (external) reason for the sudden loud whine.
Can someone advise ordering info or what model of turbo I need to buy? Its for a 2005 signature series. I thought they were all the same for the PT's but apparently not according to some sources.
Old 04 Mar 2015, 02:50 pm
All the stock turbo's are the same. Interchange wise. The aftermarket replacements. According to one of my amigos the oil holes are different inside if I got that correct. The neon has the same turbo. Nitro_PT has a good retailer on one. Without the problem.
Thank's for the thumbs up. Wanted to make it easy for simple people like myself. . Pictures are good. Lol keep me in mind for the leftovers. lol.
767skyking likes this.
Old 05 Mar 2015, 01:53 pm
Kev Kev is offline
For an extra $100 would it be wiser to buy the whole core assembly since I do not know what is shot on mine or just a rebuild kit?
As near as I can find out, the turbo model I need is a TD04LR-16GK/6, does this sound correct?
2006 Turbo Lite - Whine in first gear ct70 Tech & Performance Forum 2 14 Jan 2015 04:37 pm
Turbo Whistle/Whine - Part II soonercruiser General Turbo Discussions 4 29 Nov 2014 08:50 pm
Sudden whining out of my turbo pt artbumm General PT Cruiser Discussions 12 28 Apr 2007 04:03 am
Uncommon Turbo whine turbomangt Turbo Performance 3 27 May 2005 11:09 pm
Wasn't a turbo whine after all Mike-in-Orange General Turbo Discussions 9 03 Feb 2004 01:35 pm
