Code P2305 (secondary coil) after timing belt changed
Old 06 Mar 2015, 10:45 am
Default Code P2305 (secondary coil) after timing belt changed
Hello to all, new member here: 04 2.4 base, automatic with 153,000 and an after T-belt replaced issue. I changed the belt per milage and not due to breakage, kit Incd; belt, pump, tensioner, pully also changed cam seals, both intake seals, plugs, wires, and coolant. After assembly all was fine with no issues nor codes for 90-miles. While driving engine stopped and I located and replaced a blown fuse #13 and was able to get home in limp mode (20mph and rough idle). Test showed a code P2305 (secondary coil). I did locate that the coil had a 1/2" crack (had not noticed crack on initial assembly). Replaced coil (A-Zone) and checked all connections, and compression: 160 Lbs. at lowest cyl.. Initial start was no change to rough idle and same P2305 code. Any assist will be appreciated.
Old 06 Mar 2015, 12:34 pm
Default Re: Code P2305 (secondary coil) after timing belt changed
I would suggest checking your spark plug wires. Make sure they are not shorting to ground.
Also suggest double checking the wire connectors going to the coil. Sometimes they lose contact.
Old 06 Mar 2015, 01:08 pm
And the connectors take a lot of force to seat fully.
Other possibility is you got a new coil that is bad.
WhatElseShould Be Changed When Timing Belt Is Changed? myjeephatesme Tech & Performance Forum 5 02 Jun 2014 01:51 pm
Timing Belt -How to know if it was changed drageur General PT Cruiser Discussions 1 24 Jul 2012 11:15 am
Timing Belt Changed and now will not start - HELP rhowle Tech & Performance Forum 3 18 Mar 2012 08:59 pm
Is there any way to tell if a timing belt has been changed? jwbam General PT Cruiser Discussions 10 29 Feb 2012 08:57 pm
Timing Belt - how to tell if its been changed? dana Tech & Performance Forum 3 29 Sep 2010 03:21 am
