Well I checked the shaft play on the turbo. It's not the problem. I have no idea what this is. Honestly the turbo looks brand new like it's been replaced.
![]() 2003 Dream Cruiser #0794, MSD wires, MSD Box, Borla exhaust, K&N coldair intake, Rear fiberglass rollpan, Xenon side skirts, Rear window cover. Pinstriping on tailgate and hood. Custom teardrop tailights, drilled/slotted rotors. Custom interior, boost gauge and wideband in A-pillar, lowered on Ebach adjustable coilovers, sway bars, and bushings. Diablosport Intune with modified 93 tune. AGP aftermarket wastegate. Fresh rebuilt engine with forged wiesco pistons bored. 020"over. |
Make a video of it and post it.
You should use an audio scope or a home made one to isolate the noise. Call me and I will explain further to much to type. ![]()
To view larger pictures simply "click " on the picture! Dalai Lama "Share you knowledge. It's the best way to achieve immortality." ASE MASTER TECHNICIAN ![]() ![]() Last edited by NitroPT; 28 Mar 2015 at 12:06 pm. |
I will try. My home internet has been disabled due to at&t being too awesome...
So I'm posting from my cell.
I filmed it. And I must say that I can hear noises on the video that you can't hear in person. Im not sure if I'm being paranoid or what. Ill post it shortly.
Ive taken the valve cover off. There's no sign of wear or nasty shavings anywhere. Just by visually inspecting, it doesn't look like it would be the problem.
I was thinking after doing some research, that it might be my timing chain components? If something is loose but only makes noise under load?
It's had to tell it could even be the torque converter bolts. You need to isolate the sound better.
Make a home made listening toool. Philips screw driver. About a foot of vacuum line and a bolt. Push the hose on the shaft of the Philips and the at the other end push the threaded portion of the bolt. Now you can push the handle of the Philips I your ear and with your other hand touch different areas of the end to find where the noise is exactly coming from without have to take anything apart. |
Will do
Thread Tools | |
Display Modes | |
Weird rumbling noise in dashboard when I turn over the engine/ turn off the engine... | thinkinboutit | Tech & Performance Forum | 5 | 22 Jan 2014 08:23 pm |
Weird Engine Noise w/Video | 01limited94 | Tech & Performance Forum | 7 | 25 Jan 2013 12:04 pm |
Weird noise when engine revs | luckymagruder | Tech & Performance Forum | 2 | 20 Oct 2012 02:19 pm |
Weird Noise coming From Engine | LVActor | Tech & Performance Forum | 11 | 08 Jul 2008 02:07 pm |
Weird Noise | ptlovr | Tech & Performance Forum | 7 | 05 Jul 2006 07:14 am |
