Check engine light
Old 01 Apr 2015, 09:08 am
Default Check engine light
hello, I'm kinda new at this. I have a 2007 pt turbo, bought used (of course) no big problems (that I know of) except check engine light blinks when I've been idling too long. If I put it in neutral doesn't seem to happen. Really don't want to take it to the dealer, know what I mean? Thanks
Old 01 Apr 2015, 09:11 am
Default Re: Check engine light
Blinking Check engine light is bad.
Go to an AdvanceAuto, or Auto Zone, etc, and have them read the error code, or get it yourself
How to retrieve fault codes.
Old 01 Apr 2015, 09:20 am
Did that, no codes, just said done
Old 01 Apr 2015, 09:27 am
When the check engine light flashes, it means there is a severe drivability problem with your PT Cruiser.
For example, you leave your gas cap off or your cam sensor were to fail, the engine light would come on solid.
However, if you had a single or multiple misfire which could lead to engine damage or damage the catalyst converter if you were to continue driving it. The light would come on and flash and continue flashing.
Never drive or allow the engine to run with a flashing check engine light. Always pull over and shut it off. See if it stops flashing when you start it up but you need to fix it immediately.
How long as it been since you replaced spark plugs and spark plug wires?
Old 01 Apr 2015, 09:58 am
Just had tuneup and spark plugs/wires changed last month. Have little over 91000 miles. When the light has flashed before, I've driven on and it goes off, and it only happens when I idle a little longer, except when I idle in neutral.
Old 01 Apr 2015, 10:10 am
Was the check engine light blinking before or after you had the spark plugs and spark plug wires replaced?
Old 01 Apr 2015, 12:47 pm
Both, that's why I ended at the dealer having tuneup and spark plugs changed, but it's still doing it...
Old 01 Apr 2015, 01:22 pm
Ray_Dockrey's Avatar
Using the key dance won't always show stored codes. You need to take it somewhere like Autozone or somewhere like that that reads codes for free.
Old 02 Apr 2015, 04:17 pm
Checked codes, got P0304--4th cylinder misfire, a pending code.
Old 02 Apr 2015, 05:49 pm
When is last time plugs and wires were changed? That's an excellent start.
2004 Engine misfire and flashing check engine light fg1911a1 General Turbo Discussions 15 26 Jul 2014 06:20 pm
Check engine light yadayada0007 General PT Cruiser Discussions 6 18 Jul 2013 05:43 am
Check engine light and battery light on tay2208 Tech & Performance Forum 2 27 Jul 2011 05:44 am
Dashboard goes crazy, check engine light,oil light...... jggarza3247 Tech & Performance Forum 2 10 Jul 2011 06:23 am
Check engine light: Amber Light: power loss dbleclk Turbo Performance 2 06 Jul 2011 06:12 am
