How does a timing belt tensioner work?
Old 03 Apr 2015, 05:26 pm
Flash619's Avatar
Default How does a timing belt tensioner work?
A basic question to some, yes, but from what I've found in my personal expirience, inserting a 1/4" drive into the hole, and attempting to turn it, only damages the hole. So I have to ask, what is the proper way to prep this device before timing belt install?
(this tensioner does not have a retension pin)
I only ask because I cant get my timing belt over the tensioner. Its off by about 1/4 inch.
I can loosen the retaining bolt on the tensioner pulley, but no matter which direction I move it, I cant get the belt over it. I'm assuming I'm missing a step.
Old 03 Apr 2015, 06:32 pm
Default Re: How does a timing belt tensioner work?
Use a wrench to pull the belt slack to the tensioner side. With the belt clamped to the sprockets. the belt wont jump time while you do this.
Old 03 Apr 2015, 07:46 pm
Flash619's Avatar
.... I'm confused.
If I use a wrench on the intake cam to take up slack, it's timming will be off from the exhaust cam. If I wrench on the exhaust cam, it still move both cams causing the cams to be misaligned from the crankshaft.
Could you give an example?
Old 03 Apr 2015, 08:01 pm
.... I'm confused.
If you have the timing right then they will move together. You can use spring clamps to hold the belt into the teeth of the sprockets. If by doing this the marks wont align. You were wrong to begin with. You need to keep belt as tight as you can on the water pump side.
Old 03 Apr 2015, 08:04 pm
Flash619's Avatar
I try to keep it tight by the water pump but then it makes the crankshaft move. >.< how can I keep it all tight without things moving? How tight is tight enough?
Old 03 Apr 2015, 08:26 pm
Just enough to keep the belt from being off a tooth between the different pulleys. One you have the belt on with the exception of the tensioner. pull the belt as tight to the tensioner as you can. Then with the free hand roll the cam or crank to get to slack you need to roll the belt onto the tensioner without the belt slipping any teeth. Then you can roll the entire engine until the marks come back around.
Old 03 Apr 2015, 08:42 pm
Flash619's Avatar
Why would I need to rotate the engine? Shouldn't the marks already be aligned before putting on the belt? I know the exhaust needs to be slightly lower, but I guess I don't understand why they wouldn't be aligned already?
Old 03 Apr 2015, 08:57 pm
The exhaust needs to be lined up with the other cam. One you have the belt lopped around all the sprockets. Your just turning the engine to help get the belt over the tensioner.
Old 03 Apr 2015, 09:01 pm
Flash619's Avatar
Everywhere I've read said you need to have the exhaust sprocket a half notch lower than the intake? It's the only way I can get the belt to line up with the sprocket teeth unless... Am I missing something?
Old 03 Apr 2015, 09:07 pm
HARMONIC BALANCER & CRANK SPROCKET REMOVEL AND INSTALL TOOL AND TIPS!!!! Here is what they look like Top and bottom.
04 PT Timing belt tensioner havoc999 Tech & Performance Forum 2 08 Mar 2015 08:54 pm
Timing belt tensioner help faysCruzn Feedback and Support 8 16 Oct 2013 08:36 am
Timing belt tensioner? unioncreek Tech & Performance Forum 1 20 Jul 2012 12:00 pm
Timing belt tensioner Jeepertim Tech & Performance Forum 9 25 Nov 2011 12:39 pm
Timing Belt Tensioner Areus Tech & Performance Forum 0 17 Jun 2011 05:44 pm
