NEED HELP REPLACING HORN SWITCH!
Old 17 Apr 2015, 06:38 pm
Default NEED HELP REPLACING HORN SWITCH!
My 2001 PT failed the WV state inspection today because the horn doesn't work. I found a few posts on this website that lists of what you have to do and I've messed with the steering wheel cover for almost 2 hours trying to get it off. I have been unsuccessful in removing the airbag cover (the part with the Chrysler logo) to replace the horn switch/pad. The horn itself still works because it still works when I lock the car with the key fob, so i am assuming it is something under that cover that needs replaced. (Note: A few days ago it was working but I would have to push pretty hard on the horn button for it to work and it was intermittent at best).
So if there is anyone out there that could provide detailed instructions (A video would seriously help me. I may even consider paying someone to post a clear video of how to remove the cover. It would really help me out.
Thanks Everyone!
Old 19 Apr 2015, 04:32 am
dalandon's Avatar
Default Re: NEED HELP REPLACING HORN SWITCH!
Thanks Everyone!
Most likely its the clock spring that's bad, when I removed the air bag I bent the end of a 16 penny nail to use as a lever, there are 3 holes behind the airbag, insert the bent nail and slightly push back while lightly pulling on the bag cover you should hear a click each time and it comes off it takes about 30 seconds.
07 Remvoal of Horn button/cover
2007 Pastel Yellow PT Cruiser Touring Edition Auto 4 speed, 1 of 2473
Airaid SynthaFlow Cold Air Intake 300-198
UltraGauge EM v1.2
Bridgestone Turanza Serenity Plus 195/65r15
AKA "Banana Car"
Old 19 Apr 2015, 06:58 am
Could you post a photo of the 3 holes location? I pryed and pulled for 2 hours at that cover with no luck. I used 2 flat head screwdrivers as leverage.
Old 19 Apr 2015, 08:40 am
JUST REALIZED I POSTED IN WRONG DISCUSSION BOARD. PLEASE DELETE.
Old 19 Apr 2015, 09:16 am
Handy_Cruiser's Avatar
Read this. It should help:
How to: Aftermarket steering wheel
2001 PT Cruiser air bag horn switch gcannino Tech & Performance Forum 1 12 Mar 2014 07:24 am
Stereo not working after replacing Multifunction Switch talows Sound and Security Forum 0 11 Mar 2014 09:31 pm
Problem after replacing the multifunction switch!!! jimgas General PT Cruiser Discussions 13 21 Sep 2012 11:20 am
Replacing switch illumination MM64 Tech & Performance Forum 8 18 Aug 2011 06:34 am
Replacing AC Clutch Cycling Switch andreb Tech & Performance Forum 1 05 May 2010 08:29 pm
