need a little help
Old 16 May 2015, 01:14 pm
Default need a little help
I have an 03 gt that keeps kicking a check engine light with a p0344 code and goes in to limp mode. I have replaced the cam position sensor and the cam magnet (dealership parts). It ran fine for a few weeks and then back to the check engine light and limp mode. Not sure what would be the next thing to do. Side note: timing belt and water pump where replace 5 months ago and this problem started after that.
Old 16 May 2015, 02:53 pm
Default Re: need a little help
I would suggest checking the CPS & CKS wiring harnesses as having a potential problem especially the wiring near the drive axle getting worn,and causing a 'fault' situation. Its possible when the timing belt was replaced that the wires were moved around and with the age of the wires it possible they are brittle and have bare spots on them. This would be the first thing I would check. Check the wires with an ohm meter and wiggle the wires to make sure they are okay.
Was the timing belt double checked to make sure the timing is correct and that it is not off by one tooth?
Old 16 May 2015, 02:58 pm
I had the wiring harness to the Camshaft sensor, which runs around the back of the engine, break loose from the little plastic clips and it let the harness drop far enough to hit the spinning half shaft and burn the wires. Take a good look at the harness (and the connection to the sensor) for any signs of wear and tear.
Had to be towed from I95 in South Carolina to the nearest Chrysler dealer where the mechanic found the burnt wires while he was about to change the sensor.
Old 16 May 2015, 04:11 pm
All the wiring is in good shape and when the timing belt was put in I am not sure if it was double checked but the shop I took it to had a great reputation of going over their work with great detail. Thanks for the help.
Old 16 May 2015, 05:06 pm
Possible causes of P0344
Faulty Camshaft Position Sensor
Camshaft Position Sensor harness is open or shorted
Camshaft Position Sensor circuit poor electrical connection
Faulty starter motor
Starting system circuit
Weak battery
I would suggest checking the voltage on your battery with the engine running. Make sure you are getting approx. 14 to 14.5 volts.
Also make sure your battery is good. Have a battery load test done if you are not sure.
Old 16 May 2015, 10:25 pm
I also get the P0344 code but there is no noticeable performance change, It went out when the weather got cooler last fall. And when the weather warmed up this spring the light came back on. I just tried a gas with a higher octane and the light went off and has been off for a few days....
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 16 May 2015, 10:27 pm
Battery is good wiring is good. Changed crank sensor and everything seams to be running great now. I will let you all know if that fixed the problem. If it don't, I think it will be going to the shop and getting a complete engine overhaul.
Old 16 May 2015, 10:53 pm
Do you mean that you will be rechecking the timing belt?
Old 16 May 2015, 11:13 pm
Timing belt will be one of the first things that is checked. Because if it is off by a tooth some one other then me is going to be paying for the work.
