Bad Turbo
Like Tree3Likes
Old 25 Jun 2015, 01:27 pm
Default Bad Turbo
I have a 2004 PT Cruiser Turbo Automatic with 2.4 motor, the turbo has quit working and I want to know if u can take the turbo out and leave it and if so how do u do it. Thanks in advance for your help.
Old 25 Jun 2015, 02:00 pm
Default Re: Bad Turbo
You can remove it. Or totally remove it. You say it doesn't work explain that for us. It's got to be a real slow turd if not working at all.
Old 25 Jun 2015, 02:59 pm
The bearings in the turbo r bad, u can reach in and turn turbo any way u want. I have replaced the all vacuum hoses, timing belt and oil sending unit. It will not go over 40 mph up hill and after a few miles it starts acting like it's choking and won't go over 25 mph and engine light flashes.
Old 25 Jun 2015, 05:57 pm
Was it running this way before the work was done? Why would you want to continue to run this bad. Because the engine will not run better with out the turbo. Compression is lower on turbo than n/a.
Old 25 Jun 2015, 08:16 pm
I'm not running it at the time, it has no power and tried to die so I have it parked that's why I'm asking about the turbo. Is told u can remove it but if it makes no difference that would be pointless, I'm just trying to figure out what else to do to fix it. When I purchased the car ask the vacuum houses has been cut off, not sure what they were planning to do to it but I assume they knew the turbo was bad and just didn't say and I was told I only needed a new timing belt but that wasn't the case apparently. Sounds like I need to replace the turbo right?
Old 25 Jun 2015, 08:32 pm
Maybe. Does the impeller hit the sides of the housings?
Old 25 Jun 2015, 08:37 pm
REBUILDING THE TURBO!!!! Something to read.
Old 25 Jun 2015, 11:32 pm
Well with no vacuum hoses hooked up, its hard to say if the turbo is bad or not.
I will say that your symptoms are almost exactly the same issues I had when my turbo was dead. Not only was the shaft which holds the impellers (fan blade things) broken, but the seals inside were shot too sending oil into the intercooler and therefore into the intake and when it started choking, huge plumes of oil burning smoke were pouring out the exhaust.
Anyway first you need to try to determine if the turbo is damaged as best you can without removing it. Does the little fan wiggle a lot? Does it touch the side of the housing? Can you pull on it and will it move forward? If the answer is no to all, the turbo MIGHT be ok. Hook up the vacuum lines and see if it runs better.
Old 08 Jul 2015, 10:08 am
Angry Re: Bad Turbo
Yep turbo is no good, we took it out and checked it and it is completely shot soooo, replacing the turbo is my only choice and I have a feeling it is going to cost more than I want to hear. Anyone know the prices of them????
Old 08 Jul 2015, 03:54 pm
New PT Cruiser SRT 4 TD04LR Turbo Chra 1 yr Warranty Inc Compressor Cover SVC | eBay
I replaced mine a few months ago and didn't need a new housing or manifold. After checking around, this is what I bought for about $180. Add another $40 for the new oil line, $7 for manifold gaskets, and $20-$40 for the oil change. And when I had a problem I was able to get someone on the phone who helped me nail it.
pudd66 likes this.
Driving impressions: 05 Turbo-Lite and 06 Turbo High Output trooplewis General Turbo Discussions 31 25 Oct 2012 04:21 pm
Compare feeling of a Turbo Lite to Turbo HO mstg007 General Turbo Discussions 3 26 Jul 2012 10:00 pm
Turbo stuffs Manifold srt4 stage 3 SMT6 Turbo t3t4 50 trims and more bobgt Classifieds: For Sale/Trade 1 10 May 2010 02:29 pm
Colima Pro Street Shadow Turbo VS PT Cruiser Turbo skylight PT Cruiser Videos 5 31 Dec 2008 03:21 pm
180HP turbo lite and 215HP turbo difference. alceryes General Turbo Discussions 27 29 Dec 2003 01:57 am
