Blown turbo and oil in manifold
Like Tree2Likes
Old 30 Jul 2015, 12:25 pm
Default Blown turbo and oil in manifold
Hi guys, I blew the turbo this past weekend and started taking it apart this morning and found oil in everything...from cold side of turbo all the way to the intake manifold...so I guess the seals went south and took the turbo out...I have ordered a turbo cartridge already and want to know what is the best way to remove all the oil residue from the manifold etc...and also when this happened the car was smoking like something off a James Bond movie where he was trying to ditch the bad guys with a smoke screen...so I guess the cat is soaked in oil as well...any way to clean this out or buy a new one?
thanks for the help guys!
03 pt gt
133000 miles
Old 30 Jul 2015, 01:28 pm
Default Re: Blown turbo and oil in manifold
Coked up oil passages on the exhaust side of the turbo killed the seals. You need to inspect the oil inlet hose for coking restricting the oil flow. Oem hose are available from eBay reasonable. But it's a witch to install. The seals in the turbo are no more that a miniature piston ring. No oil and ring or seal as its called callouses and let oil from other areas blow it the back. If pvc valve goes out it will smoke as well and it will suck oil int the intake. This might be what happend here. Oil out the back of the turbo can't get into the intake.
Handy_Cruiser likes this.
Old 30 Jul 2015, 04:52 pm
A similar thing happened to one of my PTs as well. The turbo died and I had the James Bond smoke screen as well. After I replaced the turbo, I pulled the intercooler hose off the hot side. Probably a liter or more drained out. I would suggest that you do the same.
After that I simply drove it fairly hard and for about 50km, to burn off the remainder of the oil still in the system. It no longer has the smoke screen effect. Probably not the best way, but it did the trick.
Old 30 Jul 2015, 08:15 pm
Thanks guys for the info and advice...I will have to look in the pipe and see how much oil is in it!
The turbo is on its way and should be here by Wednesday.
The oil line and return line is being made by a friend that works at an oem fluid line manufacturer here in Georgia and he is going to insulate it from connector to connector just to be safe from the heat.
Old 30 Jul 2015, 08:36 pm
It's the turbo that cokes the line. If you dont run the pt untill the temp comes back down after running it hard it will cook the oil. Heat transfers up the oil line from the turbo itself.
Old 31 Jul 2015, 01:33 pm
Thanks Busted for your help!
Old 31 Jul 2015, 08:39 pm
Your welcome!
Old 03 Aug 2015, 03:03 pm
Chris_TurbosUnleashed's Avatar
WATCH THESE 3 SHORT VIDEOS REGARDING THE IMPORTANCE OF OIL SELECTION AND USING A NEW OIL SUPPLY LINE IN YOUR TURBOCHARGED VEHICLE:
The Importance of replacing your PT Cruiser/SRT-4 Oil Supply Line
Synthetic vs Conventional Oil Frying Pan Test 30 seconds
Why Synthetic Oil is important in TurboCharged Engines like yours
Chris Wright-Owner
Turbos Unleashed, Inc.
Phoenix, AZ Main Office since 1997
Vienna, Austria Europe Office Now Open!
Home of the 2 Year Warranty PT Cruiser TurboCharger
Chris@TurbosUnleashed.com
http://www.turbosunleashed.com
602-76-BOOST
602-76-26678
Old 28 Aug 2015, 11:28 am
Default Re: Blown turbo and oil in manifold (updated)
Hi again fellas, well I got the turbo in and cat converter as well and now I have dtc code(s) p0888 and p0700 now!
all I did was replace those 2 parts and 2 oil lines and now this...any ideas what is loose or causing this??
Also now the ABS and track control dash lights are on now.
Thanks for the help guys!
Old 31 Aug 2015, 07:56 am
It's fixed, seems I wiggled a relay loose somehow!
Car runs like a scalded dog now!
Turbo stuffs Manifold srt4 stage 3 SMT6 Turbo t3t4 50 trims and more bobgt Classifieds: For Sale/Trade 1 10 May 2010 02:29 pm
Blown Turbo??? MimisMom General Turbo Discussions 6 26 Aug 2009 02:57 pm
dealer wants $2900 for blown turbo alfas Tech & Performance Forum 13 13 Aug 2009 07:45 am
Blown Gear box after Turbo Charging Kboom General Turbo Discussions 4 27 Oct 2004 05:38 am
