Won't turn over
Like Tree2Likes
  • 1 Post By CREWZIN
  • 1 Post By LionPT
Old 17 Aug 2015, 12:52 pm
Default Won't turn over
I have a 05 pt turbo that died out at a red light.I towed it home and had a mechanic do a scan on the car it gave me a code for the camshaft sensor so I replaced it and still won't turn on. Car does crank over just won't start some help would be greatly appreciated
Old 17 Aug 2015, 01:52 pm
Handy_Cruiser's Avatar
Default Re: Won't turn over
I posted a response your other thread.
Old 17 Aug 2015, 02:50 pm
I didn't see anything?
Old 17 Aug 2015, 04:56 pm
If it is the timing belt would that come up on the scanner?
Old 17 Aug 2015, 06:10 pm
NO, but it would set off codes for either the Camshaft or Crankshaft sensors or both, because they would be out of time with each other.
Gabrielm55555 likes this.
Old 18 Aug 2015, 02:50 pm
I was just wondering if the timing belt broke would I have heard a loud noise or something? Cause the car just died out at a red light and I didn't hear anything out of the ordinary
Old 18 Aug 2015, 04:25 pm
I don't know about on the PT 2.4, but on my Acclaim with the 2.5, it made no sound at all, it just died. I pulled over, checked the distributor for rotation and found none. I knew what it was then. Not a bad job, but am NOT looking forward to doing it on this PT turbo.
Old 18 Aug 2015, 05:56 pm
LionPT's Avatar
Pull the Camshaft Sensor off & have someone try to start the car...if you don't see the cam spinning, the belt is broken.
Old 19 Aug 2015, 09:44 am
Thanks for the info I will try this.. I think it is the timing belt
Weird rumbling noise in dashboard when I turn over the engine/ turn off the engine... thinkinboutit Tech & Performance Forum 5 22 Jan 2014 08:23 pm
Front Turn Signal Lights Turn On and Off When Applying Brake? Danny7627 Tech & Performance Forum 12 20 Jan 2014 09:42 pm
Windshield Wipers Turn On With Turn Signal or Bump... NewPTCruiserInPA General PT Cruiser Discussions 8 17 Dec 2013 09:10 am
dome light doens't turn off till i turn on the car... realized Interior Accessories Forum 3 15 Jul 2009 06:44 pm
blue turn signal bulbs that turn orange when in us Capt Kidd General PT Cruiser Discussions 1 04 Jun 2004 10:10 pm
