PT Cruiser Forum Car Videos
Jeep Parts | Car Rims
Mopar BOV installed.
Old 17 May 2004, 10:51 am
Dragula Dragula is offline
Default Mopar BOV installed.
My thanks to those who stated that a ratcheting box end wrench was the ticket. I bought one ahead of time, and it was easy. I did struggle with the oil line, but I got everything from topside. I was even able to use an inch pound torque wrench to torque the two outside bolts to spec (in the instructions). The other had to be torqued by feel.
One thing that I think is important is to make sure there is clearance between the oil line and the bolt AFTER the installation. Mine was rubbing. I was able to bend the line just about a quarter inch away from above. You don't want to have that bolt eat through the oil line.
Note: If I had bent the oil line ahead of time it would have been much easier to start that one inside bolt.
Old 17 May 2004, 03:47 pm
Mike-in-Orange Mike-in-Orange is offline
Great tips, thanks! I'm gathering all the info I can on the intricacies of this intallation, like the ratcheting box wrench, so this little tidbit is very welcome!
Old 17 May 2004, 05:53 pm
OurPTGT OurPTGT is offline
over at SRT they recommend adding gasket sealer also. MAybe I should go back and try this [:I]
Old 18 May 2004, 08:56 am
GTPT GTPT is offline
I also found that if you loosen the bolt next to
the oil line first then remove the other two completely,
you can swing the bov down to give you a little more room
to get the rear one out. When you reinstall start the back
one first. Worked for me along with a few choice words of
encouragement.
Old 18 May 2004, 02:05 pm
I didn't add any gasket sealant on mine. I haven't had any problems yet, but it's only been on since Saturday. What are the symptoms you're having? Can't hold boost?
Black 03 PT Turbo & Black 94 Impala SS
Old 18 May 2004, 02:53 pm
Cal Cruzer Cal Cruzer is offline
Some on the SRT board reported a slight loss of boost. Using the RTV fixed it.
vB code is On
i installed my mopar stage II coil over shocks tthrift Turbo Wheels/Suspension/Handling 21 15 Nov 2004 06:12 am
Stage 1 and mopar BOV just installed...wow RossiePT Stage Turbo Kits 3 14 Aug 2004 02:55 am
part numbers Punch General Turbo Discussions 5 13 Jan 2004 11:46 pm
Mopar Press Release - 11/04/03 skylight General Turbo Discussions 15 24 Nov 2003 05:01 am
SRT-4 Mopar Performance Parts skylight PT Cruiser News and Rumors 13 23 Jul 2003 07:26 pm
  Loans | Cute Dogs | Compare UK Credit Cards | Loans | Gómez PEER
