Won't turn over
Like Tree2Likes
Old 11 Sep 2015, 03:54 pm
Default Won't turn over
OK so I have a 2005 turbo pt cruiser that cranks but won't turn over. I changed the crankshaft senor and camshaft senor . checked the timing belt it was good checked fuel pump its good spark plugs have spark changed both o2 sensor and till nothing any more suggestions !? The error codes it gives me are poo340. Poo31.. Poo37
Old 11 Sep 2015, 09:28 pm
Default Re: Won't turn over
First thing I would do is make sure you have clean contacts on the battery cables and the battery is fully charged.
2nd suggestion is to check the fuses under the hood that is related to the 02 sensors.
3rd is to check the wiring between the 02 sensors and the PCM. Take an ohm meter and check for continuity.
Old 12 Sep 2015, 06:54 am
The battery is brand new the cables are nice and clean .. I will check the wiring in the o3 sensors next thanks for the advice ...
Old 12 Sep 2015, 10:53 am
If you still getting the P0340 (after you cleared the original fault codes) then check the electrical connection to the Camshaft sensor and then check the wiring harness from the sensor, around back of the engine, to the computer. Make sure there's no chafing or breakage in the harness that would cause the signal from the sensor not to reach the computer.
Old 12 Sep 2015, 05:22 pm
Checked all the wires that connect to o2 sensor everything looks fine really puzzeled I'm hoping it's not the computer is there a way to tell if computer is bad
Old 12 Sep 2015, 05:35 pm
Have you checked the ground wire on the 02 harness for continuity?
What brand 02 Sensors did you install in the PT Cruiser?
Old 12 Sep 2015, 05:45 pm
Not the wiring to the 02 sensors, the wiring to the Camshaft sensors.
Old 14 Sep 2015, 09:03 pm
Car still won't turn over??? I've changed the camshaft sensor and crankshaft senor new tune up and still nothing anybody have any ideas
Old 14 Sep 2015, 09:38 pm
Any chance you can answer my questions?
Also have you done an engine compression check?
Old 14 Sep 2015, 10:31 pm
Check the basics first. You're pissing away money on too many "maybes". Spark, fuel, compression and air. It's got to be lacking one of these or it should crank and start.
Weird rumbling noise in dashboard when I turn over the engine/ turn off the engine... thinkinboutit Tech & Performance Forum 5 22 Jan 2014 08:23 pm
Front Turn Signal Lights Turn On and Off When Applying Brake? Danny7627 Tech & Performance Forum 12 20 Jan 2014 09:42 pm
Windshield Wipers Turn On With Turn Signal or Bump... NewPTCruiserInPA General PT Cruiser Discussions 8 17 Dec 2013 09:10 am
dome light doens't turn off till i turn on the car... realized Interior Accessories Forum 3 15 Jul 2009 06:44 pm
blue turn signal bulbs that turn orange when in us Capt Kidd General PT Cruiser Discussions 1 04 Jun 2004 10:10 pm
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
