Testing a 2003 PTGT Rad fan...
Like Tree4Likes
Old 13 Sep 2015, 10:44 pm
Default Testing a 2003 PTGT Rad fan...
Does anyone know how to test the Bosch motor for a 2003 PTGT? I have purchased a used motor and it is still not working. It is getting power, but I do not know how to signal it to turn on. Also, how would I test my car to make sure it is sending the signal to turn on the fan? Bad ECU? Ugh, 2003 has been a nightmare, please help!!!
Old 13 Sep 2015, 11:29 pm
Default Re: Testing a 2003 PTGT Rad fan...
Unplug the motor from the fan in your car.
Take the new motor and plug it into the pigtail.
Start your engine and turn on the air conditioning, the fan motor should immediately start turn.
Turn off the engine, turn off the a/c. Restart the engine and let it idle watching the temp gauge. The fan motor should begin operating when the temp gauge reaches the center line if the gauge or just before that. Then turn on the a/c and it should speed up.
If that works, replace your dead motor with the good one and enjoy your GT.
This is the procedure my son and I used except we had a complete used Turbo fan assembly and pulled the plug up to the top to plug it in to the fan socket. The fan worked just as we expected it to do so we pulled the n/a fan I have been using for a year and a half and replaced it with the Turbo unit. That was two weeks and four hundred miles ago and it works great. Now I can inspect the car. Just hope the fan will last a few more years. I'll pick up any I find though for spares. I plan on keeping this car until I die.
Daeouse likes this.
Old 13 Sep 2015, 11:35 pm
From the 2003 shop manual for the 2.4 liter Turbo:
Harness connector viewed from open end with the locating-locking tab at the top.
Top right is pin #1
Top left is pin #2
Bottom right is pin #3
Bottom left is pin #4
#1- black 10 gauge wire- ground
#2- violet/red 10 gauge wire- battery positive (fusible link)
#3- dark green/orange 16 gauge wire- auto-shutdown relay output
#4- dark blue/dark green 20 gauge wire- radiator fan motor control (part of PCM)
Busted_PT and Daeouse like this.
Old 14 Sep 2015, 12:19 am
This is the 2003, there are no relays and it is controlled by the PCM... I have just replaced the fan with a used one I purchased off of eBay and it is still not working. Could something else throw a P0480 code, like if the temperature sensor was not working? I know that has a different code, but the fan did not work after I replaced it and I cannot test it because the PCM sends a signal to turn the fan on and off and what RPM to run at. There is always voltage to the fan once the key is in the on position. So, temperature sensor?
Old 14 Sep 2015, 12:54 am
Thanks for reminding me there is no radiator fan relays in the 2003 GT.
Turbo Radiator Fan
The radiator cooling fan is a variable speed electric motor driven fan. The radiator fan assembly includes an electric motor, fan blade, and a support shroud that is attached to the radiator. The radiator fan is serviced as an assembly (fan motor/fan/shroud).
The variable speed radiator fan is controlled by the Powertrain Control Module (PCM) by way of a Pulse Width Modulated (PWM) signal. The duty cycle ranges from 30% for low speed operation then ramps-up to 100% for high-speed operation. This fan control system provides infinitely variable fan speeds, allowing for improved fan noise, A/C performance, better engine cooling, and additional vehicle power.
To control radiator fan operation, the PCM looks at inputs from:
Engine coolant temperature
A/C pressure transducer
Ambient temperature
Vehicle speed
Transmission oil temperature (automatic transmission only)
Old 14 Sep 2015, 01:07 am
Are you getting the P0480 code? Any other codes?
Does your radiator fan come on if you turn on the AC?
Does the low speed come on when it gets to about 1/2 on your gauge?
Does your high speed come on?
Old 14 Sep 2015, 01:42 am
Ill check for other error codes besides 0480 in the morning. The fan does not come on in any of those scenarios. It does not come on at all.
Old 14 Sep 2015, 06:13 am
LionPT's Avatar
Post #14
New here....and a question
Old 14 Sep 2015, 08:19 am
Originally Posted by LionPT View Post
The 2003 PTGT is different from every other year. The 2003 PTGT has a Bosch motor 4 pin connector. The only thing I would like to know is how to tell if my PCM is sending a signal to the fan to tell it to turn on.
Old 14 Sep 2015, 08:25 am
Are you getting voltage on pin #2 with the ignition off?
Are you getting voltage on pin #3 with the ignition on?
05 PTGT intake superstylz Classifieds: Want To Buy 13 01 Aug 2012 05:34 pm
WTB: 2003 PTGT ATX PCM and 2002-2006 MTX titansrt Classifieds: Want To Buy 1 03 Dec 2011 10:14 pm
New 2003 PtGt owner! slofrd General Turbo Discussions 24 02 Aug 2011 09:42 pm
How much boost comes stock with a 2003 ptgt 5spd mattsptgt General Turbo Discussions 15 28 Feb 2011 12:57 pm
SRT-4 vs PTGT (2003 models) dtbrks Turbo Performance 24 30 Oct 2003 09:54 pm
