Hissing sound through ac vents
Old 15 Sep 2015, 06:27 pm
Default Hissing sound through ac vents
So I've been driving my PT a little more often, when the car is idling you can hear a hissing sound coming through the AC vents. It almost sounds like when air is released through a valve stem in a tire. Under acceleration the sound goes away. Does the AC system have actuators that are vacuum operated and would that coincide with a slight drop in boost pressure? I'm only at 7 psi under wide open throttle. I havent made a boost leak tester yet. Thats my weekend project.
2003 pt cruiser turbo 5 spd, its a basket case
Old 16 Sep 2015, 09:36 am
Default Re: Hissing sound through ac vents
I had the same problem with my old cruiser, it was a 2008 PT classic. This problem doesn't really revolve around the turbo. I never found the solution to the problem, I was thinking of low radiator fluid or low coolant.
Old 16 Sep 2015, 10:16 am
Maybe the check valve on the power brake booster is bad. I've had cars in the past that the a/c would stop blowing out of the vents when accelertating or going up a steep hill. The solution was replacing the check valve. I don't know if this'll work for you or not. It's just a suggestion. I'd be interested to see how you make the boost leak tester. I may want to do that too!
Old 16 Sep 2015, 10:59 am
Just google srt4 boost leak tester. Lots of diy's. Ill snag a valve from my parts bin and swap it out
2002 PT.. Cool Air Entering Cabin from Vents when AC System is OFF and Vents are off. Ptdave02 General PT Cruiser Discussions 2 12 Feb 2015 03:50 pm
2005 smell coolant from vents-none in vents passive101 General PT Cruiser Discussions 12 14 Jul 2014 06:24 pm
Hissing sound hammeri Tech & Performance Forum 4 07 Oct 2012 05:39 am
Hissing sound from engine. Is this normal? HYE_PTC General PT Cruiser Discussions 5 24 Jun 2011 07:33 pm
Hissing noise jona_20017 Tech & Performance Forum 3 09 May 2011 01:46 pm
