I also would recommend full synthetic oil for the turbo. Mobil 1 is generally considered the #1 syn on the market.
![]() \'03 GT Inferno Red AutoStick - Stage 1 - Air Box Mods & K&N Filter - AMX Intake Down Pipe - Flowmaster 40 Series Exhaust - Magnacor 8.5mm Ignition Wires - Pin Stripping - Chrome Side Spears - Chrome Tail Light Covers - Chrome Fuel Door - E&G Custom Grill - Painted Rear Mud Guards - 3-D Liquid Flames - Chrome/Red Neon Washer Nozzles - Interior Neon |
the oiul filter may have been fine they might not have removed the old o ring it may have come off the old filter. I have done this with the same result
stage 1,manual bleed valve(18psi), k&n drop in , silencer removed, mopar bov and oh yeah its totalled now, waaaah |
I agree 100% with 026TB4U. I've changed my own oil for countless years on all my cars and on one occasion on a car that it was hard to see where the oil filter was,(Saturn) I got the filter off and it left the old ring from the top of the filter stuck in place. The new filter can and will go on normally and tighten up, but the pressure after starting the car up will force oil out between the old and new ring. Your problem was either that, or they forgot to give the filter and extra half turn with a wrench after they put it on by hand.
![]() ...just CREWZIN along! ® . . . PT Cruiser Links Moderator ![]() 2000 PT. 95K miles, Original Owner Visit My Home Page www.CREWZIN.com |
Blends still have dino oil in them, and for the turbo, this may be a "problem". I have been a wrench all my life, did it for 13years as a profession, and for turbo cars I believe synths are the best bet. They are less likely to fry in the turbo, you can stretch the intervals, I go about 5-6000 between changes. BUT use a quality filter, if you pay $1.99 for a filter what do you think you are getting. FRAM filters are junk, but they do have a great advertising campaign. WIX, Purolator & AC Delco are my first choices. I have read MOPAR filters are now made by FRAM but I can't confirm this. Do some searches on oil filters and read up on them, independant sources only, are your best bet.
Now let me say this, I had a 700hp small block in a race Jeep, I used dino oil in it, but it was not a turbo, and because I ran Alky I changed oil after each weekend. You don't have to use synths in a turbo car, but it is well worthit in my own opinion. Tom |
Never use a wrench to put on an oil filter, unless you have arthritic hands or don't eat your wheaties. Oil filters should be spun on until the gasket makes contact, and then another 3/4 turn after that. It is EASY to do by hand, and should never require a wrench. I have done them this way all my driving life (14 years and counting) and have never had oil leak out or the filter fall off, and you don't stress the threads or overtighten it to where you need a big wrench to get it off. With the advent of filter wrenches, everyone and their brothjer thinks they are for putting the filters on, and they are really for taking them off after some fool tightens the filter to 75 lbs-ft and then solders it on.
\"If I had a diesel rig, with a big ol\' blade, courtesy would reign, arguments abate, cuz everyone would know, I\'d SQUASH \'EM LIKE A GRAAAAAPE!\" -- Heywood Banks, \"If I Had a Bulldozer\"
I have always changed my own oil. Just like doing it
and I don't trust anybody else.I use Mobil 1 witha K&N filter.The Cruiser's are the easiest car I have ever seen to change oil in. I just started using Mobil 1 since I got my turbo. I used to change it every 1500 so now I go to 3000. So it cost me about the same as before for the good stuff.I don't use a wrench to tighten. I ues crazyjoes method.Never had a problem.
04 cool vanila Limited Turbo ![]() Wife has a 03 limited (Steel Blue) |
THier didn't say he uses a wrench, he said he "has been a wrench", which I suppose means he has been a mechanic for 13 years.
Joe
Joe R - 2003 Electric Blue PT Cruiser GT Turbo ![]() http://www.pbase.com/robinjoe/pt_cruiser |
Tom |
\'05 Limited Turbo Lite, (Silver, of course)4-wheel ABS, Sunroof, Spoiler, E&G Classic grill, K&N FIPK, BTG duals, rear lowered 1.5\", LED washer lights, $20 catch can, Aoogah horn, Weatherflectors, Sunroof Deflector, Fuzzy Dice, rear logo flames, rear pinstripe graphic, Gen3 Taillights, rear sway bar, hood struts, Strut bar. Traded in \'02 Silver Touring Edition w/87,000 miles |
The really great thing about synthetic is its ability to lubricate under high temps and stress; whatever the slime oil that is mixed with the real thing, it turns to poison when introduced to the high pressures and temps of turbocharging.
How much sludge do you want to add with each oil change? I'll take mine straight up thank you.[8)] |
| synthetic to regular oil to turbo breakdown | pppt03turbo | General Turbo Discussions | 12 | 11 Nov 2006 02:10 am |
| Manual Transmission Fluid Change | matt87951 | Tech & Performance Forum | 4 | 06 Jan 2006 07:12 pm |
| WAL MART OIL...GOOD OR BAD | rszappa1 | General PT Cruiser Discussions | 5 | 08 Jul 2004 04:34 pm |
| Radiator fluid change? | stirfry | General PT Cruiser Discussions | 2 | 03 May 2004 04:45 pm |
| True story/oil change | turbomangt | General Turbo Discussions | 12 | 11 Aug 2003 11:34 pm |
