Ima little upset
Old 21 May 2004, 06:26 pm
Send a message via AIM to sakigt
Default Ima little upset
Is that PCM TSB also for high-rpm, partial throttle fluttering and nasty backfiring?
My b/f thinks its a bad coil but my neon guy is with me on the PCM. Looks like Ill be heading up to Chrysler [}] Maybe my buddy up there can get the cost of a replacement PCM towards the Stage I kit Boost controller coming off...
Old 21 May 2004, 07:55 pm
SakiGT,
My sister-in-law had the same issue with her Neon. It was her plugs and wires. Doesn't rule out the coil though...
Crazy thing though, her Neon lost almost like 90% of its power and backfired like mad but NO CODES WERE THROWN!! (No CEL or ignition key/odometer codes)
Plugs and wires are cheap, and if you are still under 36,000 miles, they should be a warranty item.
Scott
\"If you choose not to decide, you still have made a choice.\"
Old 21 May 2004, 07:57 pm
I thought you already had S1, Saki? You ran the 14.6 with just the mbc?
tezz
Black 03 PT/GT - Autostick,Stage 1, Mopar BOV, DC rear sway, K&N filter/white baffle out, Magnaflow cat back, Eibach springs, billet strut bar, AMX CAI,3bagged UCP, Euro tail lenses, Revell shifter, misc. do-dads
Old 22 May 2004, 01:44 pm
Send a message via AIM to tthrift
yo sakigt my car was doing thesame thing and i had bad wires and a bad plugs. also some thing to remember when i started to turn my boost up i was blowing out the spark on the plugs with the higher boost.
make sure your plugs are in good shape and close the gap up some.
good luck
tommy
Old 22 May 2004, 03:03 pm
Sakigt
Change the plugs and wire's.
culprat@sbcglobal.net
Old 22 May 2004, 05:11 pm
Im running Champion plugs...forgot what I gapped them at but it was a little less than stock.
Anyone have any suggestions for wires? Why stay stock?
Id rather try anything else first than return to the stealer. If it doesnt work I can always put the stockers back on and drop him off...
Yea...I ran the 14.6 at controlled 15psi w/ a ghetto-rigged intake (airraid with no bottom). Bwahahaha
14.67 @ 94.5 <--- Self Proclaimed Fastest East Coast PT with Black wheels!!!
Old 22 May 2004, 08:02 pm
Send a message via AIM to macster
Try .045 gap on the stock plugs. I picked up a .7MPH gain at the track by going to a .45 gap.
m~
Don\'t help me
Help the bear
Patriot Blue PTGT, Stage1, K&N Typhoon, 2.5\" Cat back exhaust, Sun Hyperground, Sun HOT INZAMA Hyper Voltage system, Adams Uppipe
Old 23 May 2004, 11:05 pm
Try these have heard nothing but good things about them
I would go with the 8.5's or higher
http://www.revelenterprises.com/pt_cruiser_magnecor.htm
04 cool vanila Limited Turbo
Wife has a 03 limited
(Steel Blue)
