Plastic Intake Manifold Seals - Turbo Same as N/A?
Like Tree3Likes
Old 19 Nov 2015, 07:53 am
Default Plastic Intake Manifold Seals - Turbo Same as N/A?
Do the plastic intake manifolds on the turbo engines use the same seals as the naturally aspirated engines?
I'm asking because I had to remove the cylinder head from my PT due to some leaky exhaust valves. In my FelPro gasket set, it has paper intake manifold gaskets that appear to be for the aluminum intake, but my '05 has the plastic intake. I am hoping I can get some seals for a N/A car for my turbo car.
While I am asking, did Chrysler switch from aluminum to plastic intakes on turbo cars in the 205 model year? My daughter's '05 GT has the aluminum intake and my '05 Limited Turbo Lite has the plastic one.
Also, what are the differences between the turbo lite and the GT turbo in 2005? Where does the GT's extra output come from?
Old 19 Nov 2015, 10:32 am
Default Re: Plastic Intake Manifold Seals - Turbo Same as N/A?
Dunno.
Yes. It was a "running change" - started out with aluminum, then switched to plastic - mine has the plastic.
Engines are identical. The difference is in the computer that allows more boost for the GT.
myckee likes this.
Old 19 Nov 2015, 10:53 am
Yes and as well as the muffler. I was able to conduct some very basic experiments using a NA, Turbo Lite and GT mufflers. The most restrictive is the NA, followed by the Turbo Lite, and the most free flowing is the GT.
Installing the muffler onto the over axle pipe, with no clamp and just a fairly snug fit on all 3 mufflers tested, the NA had A LOT of restriction causing lots of gas and water to push out from that snug fit. The Turbo lite had less leakage, and the GT had none that I could see or feel. Hardly scientific, but a pretty good indication of restriction to me.
Old 19 Nov 2015, 11:04 am
The question about PT Cruiser model mufflers (not resonators) was specifically asked to ED PETERS retired Engineer for Chrysler and the answer was that the CFM flow rate of the mufflers were the same only the pipe size and slight internal baffling for sound quality was different.
Old 19 Nov 2015, 11:15 am
I am just sharing my observations. Believe what you like.
The NA muffler is considerably heavier than the other two. The GT is the lightest. I however did not bother weighing any on a scale. Again, my observations.
Perhaps without those baffles, all three the mufflers flow the same since the input and outputs are the same diameter. The addition of those baffles seems to have a drastic effect on flow, based upon my unscientific observations.
Old 19 Nov 2015, 11:17 am
And it is a good observation!
Naturally!
Here you go.
Make the call discuss your findings with ED!
http://www.ptcruiserlinks.com/forum/...oem-facts.html
Old 19 Nov 2015, 11:26 am
Why? Id Ed going to try to convince me that I shouldn't believe my own senses? LOL As I said, believe whatever you like. Cheers!
Old 19 Nov 2015, 11:33 am
Most of the time I don't quote other's when responding anymore as I have grown tired of trying actually trying to inform members of facts verses fiction about PT Cruisers. In this case it is not about what you believe but the ability if one desired to obtain empirical information from an actual Engineer that was assign the Powertrain Management and development of a Chrysler corp. in Toluca Mexico where PT Cruisers were manufactured.
Old 01 Dec 2015, 10:21 pm
I'm going to answer my own question and state that yes, the upper and lower intake manifold seals for the plastic turbo intake are the same as the naturally aspirated ones. I bought some for a N/A engine and they fit like a glove.
Old 12 Dec 2015, 02:47 pm
Chris_TurbosUnleashed's Avatar
Our first experience in ordering the o-rings for the plastic intakes was frustrating because they kept delivering the gasket for the earlier aluminum manifold. We quickly realized that the N/A gasket is the correct version for plastic intakes. Don't pay much attention to the non-turbo applications so not even sure if those gaskets would fit the N/A intake. We alerted corporate regarding the error but getting them to update this in their catalog is very unlikely.
When Ed Peters spoke at our Phoenix Convention in '97 he was already retired several years. Did he go back to work at Chrysler after that to work on the PTs?
Long distance calls weren't free back in the '90s, but, Ed and I would spend hours on the phone chatting about the best combination of parts to use. It was worth every penny. Can't say enough good things about the guy. This community is extremely fortunate that Ed takes his personal time to share his past experiences with us. Most other engineers retire and go find a quiet place to hide.
Chris-TU
Handy_Cruiser likes this.
Chris Wright-Owner
Turbos Unleashed, Inc.
Phoenix, AZ Main Office since 1997
Vienna, Austria Europe Office Now Open!
Home of the 2 Year Warranty PT Cruiser TurboCharger
Chris@TurbosUnleashed.com
http://www.turbosunleashed.com
602-76-BOOST
602-76-26678
Turbo PT Cruiser Upper Plastic Intake Manifold madscientistdohc Classifieds: Want To Buy 1 27 Jul 2015 08:40 am
Plastic Intake manifold replacement cleven Tech & Performance Forum 6 12 Dec 2012 07:27 pm
Plastic Intake Manifold Kit and Others?? slipstream74 Turbo Performance 21 08 Aug 2011 08:44 am
FS: Plastic Intake Manifold RedRum03 Classifieds: For Sale/Trade 0 07 Jul 2010 11:09 am
question about plastic intake manifold steve smith Turbo Performance 32 22 Mar 2006 11:23 am
