PT Cruiser Forum Car Videos
Jeep Parts | Car Rims
Trouble shifting into 3rd gear on 5-speed GT
Old 23 May 2004, 08:54 pm
purplept purplept is offline
Default Trouble shifting into 3rd gear on 5-speed GT
I've been hesitant to post this, but sometimes I have trouble shifting into 3rd gear on my '03 PT GT 5-speed with 9000 miles. It's probably just my shifting technique, but I sometimes miss 3rd gear when shifting briskly, when leaning more than normal, or when shifting much slower than normal. I don't get any grinding or anything like that just can't get the shifter into 3rd on the first try sometimes. Maybe I just overshift. My fellow 5-Speed PT GT owner's comments would be appreciated.
Old 23 May 2004, 10:42 pm
ksquared11 ksquared11 is offline
I have the same problem. It really pissed me off when I was at the track last week. Under normal conditions I have no problems but under hard acceleration sometimes I miss the shift into 3rd gear. Mopar is coming out with a short throw shifter that I plan on getting if they ever release it.
Old 23 May 2004, 10:59 pm
Mean Green Mean Green is offline
I have the same problem. With a normal shift no problem. Getting on it I can miss third gear very easily.
\'05 Stone White SRT4
\'04 Graphite PT Automatic
Old 23 May 2004, 11:39 pm
flashbk2 flashbk2 is offline
Same here ,although mine is somewhat better since installing the "booger bushings" . However I have the B&M sport shifter from my '01 installed also , so if I miss I hit 5th .
\'03 Electric Blue 5 speed GT, addco oversize sways,wildfire strut bar,color-matched rear muds,xenon sides/\"crusher\",mirrors,b&c pillars,both interior consoles,b&m sport shifter,autometer ultralite gauges,Mopar STG 1 ,booger shift bushings,mopar bov,AMX turbo up pipe,Prototype turbo ucp, 05 intake, map clamp
Old 24 May 2004, 01:10 am
PTGT Redman PTGT Redman is offline
Ya, the shifter is sloppy. Put in booger bushing also, so it's a little crisper, but the throw from 2 to 3 can be less than concise.
Homepage:
Old 24 May 2004, 02:40 am
PTGT_Boy PTGT_Boy is offline
My problem is downshifitng from 3rd. Sometimes, when im deaccelerating for a turn , I try to downshift from 3rd to 2nd and all of a sudden my gear box freezes and I'm unable to shift to any gears. I tried double clutching, but it doesn't free up the gear box. It takes about a good 5 to 10 seconds before I'm allowed to shift again. So far this has happen only 2 times and I'm starting to think my syncs were off due to the speed I'm trying to take the turns.
I'm just wondering if all manaul transmissions have a problem on the gear box freezing from time to time?
Old 24 May 2004, 03:13 am
Red GT Red GT is offline
Don't get mad guys but no problems here. But, I will admit to having to mussle it into reverse. Have had our GT for a year the first week of April and am finally getting it into reverse really easily now.But, the rest first through fifth easy as can be. Love this car soooo.... much.
Old 24 May 2004, 03:19 am
I was reading tips on driving manual better and read something interesting.....
Tip said:
With many manual transmissions, shifting from neutral to first gear will cause an audible grinding of the transmission’s synchronizer rings.
Avoid shifting directly from neutral to first gear. Instead, move the shift lever briefly into second, then shift into first gear. And never rest your hand on the shift level or your foot on the clutch pedal. Use you right foot for both the accelerator and the brake. Use your left foot for the clutch.
My question is: From a dead stop, I'm not suppose to start from neutral to first, but **** slighty to 2nd than to 1st to start? Sounds kinda funny to me....
Old 24 May 2004, 03:24 am
I've never had to do that. Sounds bazar to me. This car has been the best shifting car I've ever driven, and have been driving sticks since '82.
Old 24 May 2004, 03:36 am
Gary04GT Gary04GT is offline
quote:Originally posted by purplept
...I sometimes miss 3rd gear when shifting briskly, when leaning more than normal, or when shifting much slower than normal. I don't get any grinding or anything like that just can't get the shifter into 3rd on the first try sometimes...
I experienced the same problem with my 03GT 5-speed. This was one of the reasons I switched to the Autostick when I got my 04GT.
vB code is On
Error Codes skylight Tech & Performance Forum 6 07 Apr 2007 02:19 pm
How u drive ur Manual? Ctown General PT Cruiser Discussions 6 07 Jun 2004 08:09 pm
RPM's for shifting 5 Speed RJ Tech & Performance Forum 3 17 Apr 2004 08:50 pm
and so it begins 026TB4U General Turbo Discussions 3 13 Jan 2004 07:04 pm
  Unblock Myspace | HP Laptop | Budapest Accommodation | Budapest Accommodation | HP Laptop
