Getrag swap
Like Tree2Likes
  • 2 Post By _PTGT03
Old 02 Jan 2016, 09:51 pm
Default Getrag swap
I have an 03 pt cruiser gt auto/stick. Recently ran into issues with my transmission. It's leaking fluid heavily and I replaced the front seal,but it didn't help at all. A little background story.... I had engine replaced at local shop everything was going fine until both of the tranny mount bolts let loose and tranny dropped onto the kframe and It broke my axle. I tightened bolts back in fine and replaced the axle I hoped no other damage would come from that. But ever since then my tranny is just pouring fluid out between engine and tranny near check cover. So im now looking into swapping out auto getrag 5speed. I found an entire 2006 gt 5speed parts car...will that year tranny work for mine? I can change everything out since it's all there. Thanks for any advice!!
Old 06 Jan 2016, 06:56 pm
_PTGT03's Avatar
Default Re: Getrag swap
you just need to carry over the wiring harness and computer ! change transmission, mounts and axels.
i've only done the swap on a suzuki swift but not these cars.
Old 07 Jan 2016, 02:40 pm
As well as the intermediate shaft, shifter, shift cables, and possibly the console. As well, the instrument cluster is different on the manuals. You will not be able to use the computer or cluster from your 06 donor car since the 06+ cars had entirely different electronics. Not sure if the console from the 06 will fit in the 03 either.
If you need an 03 manual computer, I probably have one here I could sell. I also have a cluster, but it is from a Canadian car so it will display Kilometers instead of miles.
Old 17 Feb 2016, 02:52 pm
Thanks you info..I did find an 04 donor at a yard and they have everything I need except for flywheel,clutch,and computer key/skim so hopefully if everything goes as planned I will be purchasing it all.
Old 18 Feb 2016, 08:58 am
Fk5 Fk5 is online now
Seems like a ton of work. If you are going to go to the trouble of buying a flywheel, you might consider ditching the dual mass. It was responsible for one of the more annoying and difficult to diagnose problems on my car.
Some of the guys with real power have a vendor that will supply them and I'd probably go that way. Look for Chris15's build thread. He makes some real power and has some clutch and flywheel solutions. It's at least worth a look considering you'll be paying for a flywheel anyway.
2003 GT 5 speed
162,000 miles
Old 18 Feb 2016, 09:20 pm
_PTGT03's Avatar
i bought a valeo one-piece flywheel conversion kit from rock auto. much more responsive feeling.
Fk5 and Handy_Cruiser like this.
Old 19 Feb 2016, 10:32 pm
WrenchnIswhatIdo's Avatar
.Sorry
don't mean to jack this thread But got to ask .?
what year of suzuki swift.?
Old 19 Feb 2016, 11:01 pm
_PTGT03's Avatar
the car i swapped was a 2000 pontiac firefly (canada domestic market) . they never manufactured the 5 speed in the 2000 year cars. the transmission was from a 95 firefly. all i had to do was change some wiring, i kept the automatic harness but made attachments for the reverse switch and kept the reverse pedal switch closed. i had to drill a hole and swap the brake pedal assembly for the clutch and make a cutout on the firewall to work with the shift rods. in fact u can keep the automatic computer and the car will still work the same.
but working on suzuki cars is almost ten times easier than these chryslers are. u may even have to end up by removing the engine i'm not sure but a lot of parts have to be removed to just get to anything on the pt cruiser.
Getrag counterweight or a model of the SpaceX Dragon capsule? Bleys Tech & Performance Forum 6 22 May 2015 11:32 am
Getrag M/T fluid change 71cuda2 General PT Cruiser Discussions 3 16 Feb 2015 08:41 am
Getrag Shifter 767skyking Classifieds: For Sale/Trade 2 31 Oct 2012 01:11 pm
Manual Getrag Tranny??? Ironman Tech & Performance Forum 10 22 May 2011 10:02 pm
bleeding getrag slave thumperz Tech & Performance Forum 0 28 Nov 2009 03:19 pm
