Paulw
Old 06 Jan 2016, 08:12 pm
Default 05 Turbo-speed/od/shifting problem...
05 PT Turbo Convertible-Speedometer and odometer stopped working.
Trans goes into limp mode occasionally. When that happens, I pull off the road
and restart engine 2-4 times and it starts shifting ok...still some jerkiness upon shifting, sometimes.
I just installed new output speed sensor. Seems to shift better (smoother) but
speedometer and odometer still not working.
Any suggestions?
Thank you,
Paul
Old 07 Jan 2016, 02:35 pm
Default Re: Paulw
I would start with getting the car scanned to see which, if any, DTCs (Diagnostic trouble code(s)) are present and go from there. You need to use a higher end scanner which is capable of reading the trans codes. Not all of the cheap scanners can do it. The built in code reading by doing the 'key dance' will not display the detailed trans codes.
Old 07 Jan 2016, 04:59 pm
Default Re: Paulw
Read this. It might help:
All the lights on the panel go on and needles (gas, mph, tac) go down
Original join date: SEP 2003
Steve/ Wayne NJ
2005 GT Vert / Black / 5 speed
2004 Dream Cruiser / 5 speed Traded for 12 Veloster
2003 GT / Blue / Auto /sold
2001 Touring/ Silver / 5 speed /sold on E Bay
