idle fluctations
Old 03 Feb 2016, 09:07 pm
Default idle fluctations
There are times when coming to a stop the idle does not drop then when you are stopped the idle may stay at 1000-1200 instead of dropping down to around 750. If you pump the pedal it returns to the fast idle.The idle may stay there for a minute or so before it drops or may just stay there. If you turn the car off and restart the idle will be normal. There are no codes. I've checked the throttle body and it's clean as a whistle. The pedal cable is free and not binding.
Any ideas, I love my 03 GT and this is annoying.
Thanks for your input
Old 03 Feb 2016, 09:22 pm
Default Re: idle fluctations
I would suggest you check the vacuum lines going to the brake booster. There is a vacuum fitting next to the brake booster and sometimes the rubber cap rots out and start leaking if there is a rubber cap on it.
Old 17 Feb 2016, 09:40 am
wrong post.
low idle jimbarto Tech & Performance Forum 13 16 Jan 2016 10:59 am
Stalls at idle. Sometimes. And rough idle scatgo1 Tech & Performance Forum 6 27 Nov 2014 11:04 am
Rough Idle-Replacing the IAC Idle Air Controller engineerrock Tech & Performance Forum 9 07 Jun 2014 07:24 pm
odd idle PTconquest Tech & Performance Forum 2 27 Sep 2011 12:20 pm
ruff idle at idle only? KRNFIRE General PT Cruiser Discussions 16 23 Jan 2009 09:08 pm
