VSS (output) sensor . . .
Old 04 Feb 2016, 08:59 pm
Default VSS (output) sensor . . .
Does it only run the speedo ?
or does the ECU use it it any spark or fuel maps ?
Old 04 Feb 2016, 09:28 pm
Default Re: VSS (output) sensor . . .
Not sure about Chrysler but my mustang will but only for the mph limiter. It will add fuel by multiplying the fuel table by a number greater than 1 until it runs rich. At the same time it multiplies the timing table by a number less than one. So it adds fuel and pulls timing. They refer to this as torque limiting. It's an effective way to limit speed gently. I would suspect Chrysler would do something similar. For me (on a ford)that is the only way speed affects timing and fuel.
Old 04 Feb 2016, 10:06 pm
The Vehicle Speed sensor or VSS measures transmission/ transaxle output or wheel speed. The ECM uses this information to modify engine functions such as ignition timing, AF ratio, transmission shift points, and to initiate diagnostic routines.
orc output driver#1 steve2908 Tech & Performance Forum 2 19 Jul 2015 02:39 pm
Alternator Output scatgo1 Tech & Performance Forum 2 16 Feb 2015 10:41 pm
2.4 turbo High Output dvboth Tech & Performance Forum 5 08 Mar 2008 06:33 pm
What to do with a low output 2.4T? l337raceryo General Turbo Discussions 14 26 May 2004 03:55 pm
GT HP Output PAWANDCAW General Turbo Discussions 16 27 Aug 2003 10:24 pm
