03 Pt Cruiser with no turbo
Like Tree2Likes
  • 1 Post By Fk5
  • 1 Post By quicksilverdon
Old 04 Feb 2016, 11:15 pm
Default 03 Pt Cruiser with no turbo
Hi everyone,
I have a 03 pt cruiser 2.3L Turbo, but the previous owner removed the turbo and just put a regular exhaust manifold on and plugged up all of the lines that ran to the turbo. The thing is it has a check engine light because of it.. Can i just reflash/reprogram the ecu to a non-turbo pt cruiser program or even swap it out with a ecu from a non turbo pt cruiser?
Thank you,
subclassic
Old 05 Feb 2016, 08:41 am
Fk5 Fk5 is offline
Default Re: 03 Pt Cruiser with no turbo
How does it run? The turbo should have lower compression than an NA car. would expect it to be kind of a pig.
I don't think you can just swap computers. It would probably be easier and more cost effective to return it to stock with the turbo. The turbo itself is pretty durable. You should be able to pull all that stuff at the junkyard for a fair price.
Handy_Cruiser likes this.
2003 GT 5 speed
162,000 miles
Old 05 Feb 2016, 10:27 am
Handy_Cruiser's Avatar
+1. The car will never be right unless restored to the original configuration. If it was me, I would do as Fk5 suggested if the car was worth it. And if not, I'd just drive it with the check engine light on. Doing a bunch of work just to kill the check engine light is a worthless pursuit unless you fix it right with a replacement turbo.
And the turbo PT's do show up at salvage yards. So if you look around, you can like find one or two to get parts off of.
Old 05 Feb 2016, 10:54 am
I thought I couldn't pass inspection with a check engine light on. Maybe I misread going to recheck, and I live in Texas if anyone knows the law on that.
Old 05 Feb 2016, 11:13 am
Fk5 Fk5 is offline
You can't pass in NY. I doubt you can anywhere that checks.
2003 GT 5 speed
162,000 miles
Old 05 Feb 2016, 11:35 am
What is the error code? Most likely the cause of the engine light has nothing to do with the absence of the turbo.
Many places, like AdvanceAuto, will pull up error codes for free.
Find out the cause of the check engine light and go from there.
Old 05 Feb 2016, 02:49 pm
Does Texas even check that? I thought they were pretty well dead set against those kinds of socialist trappings like we are here in Arkansas.
2003 pt cruiser 2.4l Turbo came without turbo subclassic General Turbo Discussions 26 14 Jun 2016 12:57 pm
PT Cruiser Turbo fun Bigjoedo General PT Cruiser Discussions 3 09 Feb 2012 07:01 pm
Is my Cruiser turbo? joegosox General PT Cruiser Discussions 15 10 Jul 2011 08:18 pm
Colima Pro Street Shadow Turbo VS PT Cruiser Turbo skylight PT Cruiser Videos 5 31 Dec 2008 03:21 pm
Turbo on non-turbo cruiser 04VanillaCruiser General Turbo Discussions 7 02 Aug 2005 07:59 am
