2003 pt cruiser p0300
Old 06 Feb 2016, 11:18 am
Default 2003 pt cruiser p0300
I have a 2003 pt cruiser 2.4 and a p0300 and can't find the problem new cam sensor crank sensor coil plugs wires timing belt map sensor. Not to sure where to go now
Old 06 Feb 2016, 11:51 am
Default Re: 2003 pt cruiser p0300
Might be dirty injectors. Try some Berryman B-12 Chemtool. It can't hurt.
Did you use Mopar cam and crank sensors or "mystery brand"? There are posts of folks who tried "no-name" senors, still had problems, then used Mopar sensors and cured the problem.
Old 06 Feb 2016, 12:14 pm
P0300 - Multiple Cylinder Misfire Detected
Possible Causes:
1. Air leak in the intake manifold, or in the EGR or EVAP system
2. Base engine mechanical fault that affects two or more cylinders
3. Erratic or interrupted Crankshaft or Camshaft Sensor signals
4. Fuel delivery component fault that affects two or more cylinders - dirty or sticking fuel injector
5. Ignition system problem - coil or plug in two or more cylinders
6. Vehicle driven with low fuel pressure or while very low on fuel
I would suggest checking your fuel pressure first.
P0300 code 66Edition Tech & Performance Forum 0 20 May 2015 04:38 am
P0300/P0335 Puddin Tech & Performance Forum 2 15 Mar 2014 06:56 pm
P0300 Code, Running Troubles: 2003 PT Cruiser Touring PPCK Tech & Performance Forum 4 06 Sep 2013 01:31 pm
2008 PT Cruiser P0300 issue. Help!!!!!!!! demonacm50 Tech & Performance Forum 12 13 Mar 2013 05:01 pm
Code P0300 rszappa1 Tech & Performance Forum 2 30 Nov 2005 12:47 pm
