Just put in my Stage One ECU, now I have a whistle under boost
Like Tree2Likes
  • 2 Post By Moparman440
Old 09 Feb 2016, 04:41 pm
Default Just put in my Stage One ECU, now I have a whistle under boost
Thanks to FWD Performance, I am the newest member of the Stage One Club. The mailman delivered my ECU last night. I put it on today, and I do enjoy the newfound power, but it makes a whistling sound under boost. Not all the time, but if I am doing 45-50 in 4th gear and then suddenly snap the throttle wide open so that it downshifts into 2nd, it will whistle until I let up on the throttle.
I'm thinking that the increased boost pressure is causing a leak somewhere. Where should I look first?
'05 GT Convertible Automatic (daughter's, she calls it "Matilda", I don't) and '05 Cool Vanilla Limited Turbo Lite "Vanilla Thrilla" (wish it was a stick shift)
Old 09 Feb 2016, 05:12 pm
Default Re: Just put in my Stage One ECU, now I have a whistle under boost
The Stage 1 by itself will not create new noises.
The increase in boost level created by your Turbo Charger may be a new noise to you that you are not familiar with??
You really should either test your intake system and/or get a OBDII scanning device to see how your boost psi are relating to the new stage 1.
In order to get a better DELTA naturally you really should re-install the stock PCM connect your scan device and make some notes of the stock operating perimeters. Then install your STAGE 1 and do the same information gathering.
But if you did not first do what was suggested in this thread I have supped the link to below you may have more difficult time solving any new or already existing issue that may have increased with the installation of the STAGE 1 PCM
Check out this thread.
Adding Perfromance PT CRUISER parts
Old 10 Feb 2016, 02:10 pm
It sounds like a tea kettle boiling. I need to get under there and snug up the connections, I guess.
I have been meaning to do a compression test since I had the head rebuilt, but the Stage One came in more quickly than stated and caught me off guard.
Old 10 Feb 2016, 02:49 pm
I was suggesting in my first response to do a Intake Pressure Testing.
Old 11 Feb 2016, 04:29 pm
Thanks Nitro! I was not aware that there were intake pressure testers. I can make or buy one and find that leak for sure.
Stage 1 with dual stage boost and wastegate dmkolb Stage Turbo Kits 11 25 Apr 2008 08:55 am
Whats the max boost for pt gt with stage 1 jaspersnowstorm General Turbo Discussions 2 01 Jul 2006 04:06 pm
Stage I boost levels? ptgtcb Stage Turbo Kits 9 16 Feb 2004 09:26 pm
Stage 1 and boost controler? Airbillster Stage Turbo Kits 7 17 Dec 2003 11:42 pm
??safe boost w/stage 1?? knowyourturbo Stage Turbo Kits 2 23 Sep 2003 08:28 am
