Part Recommendations
  • 1 Post By JoeX
Old 21 Mar 2016, 02:58 pm
Fk5 Fk5 is offline
Default Part Recommendations
Okay, it looks like I am going to have to pull the trigger on some parts for my repairs. I would like to ask the voice(s) of experience about brand names and suggestions:
Radiator: I thought I read the turbo an NA radiators were different, but I can't tell how. I also don't know if mine still has a turbo rad since it was changed in June 2014. I have seen that some (Rob with the Mustang) have had success with the ultra-cheapies from rock auto. Any pros/cons? Are there any that don't have plastic tanks crimped on to the metal core? Both of mine have leaked at the crimp. I thought Spectre was one of the cheapies, but they are $107.
Intake gasket sets: My car has the aluminum intake. Rock Auto has three sets, DNJ for $4, Fel-Pro for $4 and Victor Reinz paper for $5. Is any preferable? Is there a better place to get them? Any tips for install?
Alternator belt? I would have assumed any name brand was okay - Gates, Delco, Continental, Goodyear, Delco. The prices seem all over the map though. I never of Bando, but they have the same part number as Contitech which I would have thought was Continental. I would usually have faith in myself on this one, but since I am asking the other questions and I think somebody posted that they had problems with some cheap autozone belts I figured I would add it to the list.
Also have to order a set of Booger Bushings. The engine side shifter bushings no longer exist.
I am not as concerned about warranty as I am about quality. The parts are cheap enough, but I don't want to have to do these jobs twice. (Three times in the case of the rad)
2003 GT 5 speed
162,000 miles
Old 21 Mar 2016, 03:50 pm
Handy_Cruiser's Avatar
Default Re: Part Recommendations
On the radiator, check the Advance Auto website and use the TRT41 discount code if it's over $100. There's more codes here if it starts out less than $100. But with antifreeze and other stuff you will need, it likely will be. This may well be cheaper than RockAuto because there will be no shipping cost if there's a Advance close to you.
http://www.retailmenot.com/view/adva....com?c=4342826
For belts, I like the Gates blue racing belts. See the numbers for a 2005 GT in the photo below:
For the gaskets, check the price on RockAuto for a Felpro full head set. You likely need a valve cover gasket too. And I found that the entire head set was cheaper to get both intake and valve cover gaskets. Plus you get other goodies as well. And I prefer Felpro gaskets.
Old 21 Mar 2016, 05:02 pm
When your installing the radiator make sure it fits flush with its mounting on the car. Sometimes a little bump is enough to push back the radiator mounting frame enough to knock it out of plumb. When you tighten the attaching bolts you twist the radiator causing premature failure at the crimped ends.
Fk5 likes this.
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
New guy in need of UCP recommendations vessamj Turbo Performance 9 07 Sep 2012 07:37 pm
Need recommendations LindsPT Tech & Performance Forum 10 18 May 2011 04:32 pm
Recommendations Pat1USMC Wheels, Tires, Suspension 4 20 Jan 2010 02:59 am
Recommendations for a PT toolkit thender Tech & Performance Forum 5 16 Nov 2009 09:31 am
Brake recommendations please... jodyberry General PT Cruiser Discussions 7 21 Sep 2008 06:42 pm
