PT Cruiser Forum Car Videos
Car Rims
Ran best of 14.2 @ 95mph at Cali Speedway
  #11 (permalink)
Old 31 May 2004, 09:54 pm
macster macster is offline
Send a message via AIM to macster
quote:Originally posted by sakigt
Did any of you happen to reset your PCMs? If the PCM compensates the extra hp from the intake the logic thing to do would be to reset it, correct?
I should be getting the kit in this week so next wed. Ill be at gainesville to test this all out. I'll run it as is, reset the computer then run again. Ill be dumping all kinds of fuel...
I have an autostick which was set in 1 for the start of the run.
I've had the pipe on and currently I don't run it. It didn't do anything for my 1/8 mile times.
As far as resetting the PCM. I did that when I first installed it and I got an increased senstation of power. But afterwards it (the power was gone). If the PCM adjusted for it then, it won't do me any good, which is why for me it's off. But I would need to test it on a 1/4 mile to be sure. Another thing, is that anytime I reset the PCM I get an increased sensation of power. So the only time that I will be satisfied that I'm getting a power increased from an item is after I have driven with on for awhile and then taken it to the track. If I just want to have the bestest, fastest run then I will disconnect the PCM before I run. FYI, I logged the track results from the MODs that I have incorporated on a spreadsheet, with dates, times, etc so that I can validate what if any improvements I received from installing them.
My MPH will be improved by me opening up my exhaust. I will go will a 3" downpipe and 2.5" all the way back and will tweek my spark plug gap some. Once I do that and verfiy the results I will go to the next phase. Also, I spin a bit at the start (because I run 40 psi all the way around) and I do some things there to improve my times a bit.
m~
Don\'t help me
Help the bear
Patriot Blue PTGT, Stage1, K&N Typhoon, 2.5\" Cat back exhaust, Sun Hyperground, Sun HOT INZAMA Hyper Voltage system, Adams Uppipe
  #12 (permalink)
Old 31 May 2004, 10:09 pm
sakigt sakigt is offline
Send a message via AIM to sakigt
My b/f refuses to believe me on this PCM compensation issue...anyone have the link saved where 3bar explains it?
edit** also another thing may be that the added power after resetting the pcm may be due to the dumping of fuel....
14.67 @ 94.5 <--- Self Proclaimed Fastest East Coast PT with Black wheels!!!
  #13 (permalink)
Old 01 Jun 2004, 01:49 am
rice_killing_GT rice_killing_GT is offline
Rice: although the DRs helped your 1/4, your mph probably couldve been higher w/o them. Do you have the autostick or 5 speed
Getting different kinds of turbos and mods is really helping me thinks...I'll bet anything your times wouldve gotten better if you had more time to run...The night I ran my 14.6 I ran a 15.51, 15.9, 14.9, 14.7 then finally the 14.6....
I have autostick, I was almost sure I was gonna hit 13's if I could've gotten another run. Hopefully next time.
R_K_GT
\'03 Electric Blue GT, silencers removed, K&N intake, Blanes Hood Struts, Emblems removed from rear hatch, Stage 1, Mopar BOV, Eibach springs, 18x8 Mille Miglia EV-R on 225/40/18 BFG g-Force T/A KDW 2, Eibach sway kit F&R, BTG Strut Bar, Chrome fuel door, custom 3\" cat-back exhaust with Magnaflow High-flow muffler, Blitz Dual Turbo Timer, Autometer Triple gauge pod, Autometer Ultra-lite with boost/vac, oil press and water temp gauges, Turbochargers.com wastegate, turboxs DSBC, Adams UCP, Dynoworks motor mounts with more to come.....
  #14 (permalink)
Old 01 Jun 2004, 07:30 am
hyracer hyracer is offline
R_K_GT,
On your next outing try running 15 lbs. boost instead of 17 lbs. boost and see how it drops your ET's and increases your MPH. I've been reading up on Map Clamps on the SRT4 forums and our computers drasticly pull timing on any boost over 15 lbs. You can buy a Map Clamp for $40 and have it preset at 4.5 volts. That will maintain the timing at about 22 degrees instead of about 12 degrees your getting now when you push your boost to 17 lbs. From what I've read the MC is good for about 20 WHP. (For those of you with Stage 0, a MC is NOT the way to go as your car will run too lean without the bigger injectors and additional programming of S1).
I've run 14.40's with just S1 and the $1 spring mod, so I'm thinking you should be running high 13's with all your "toys" and the addition of a Map Clamp. I'll be trying this out myself sometime in July when I get back from vacation.
Cheers, Deen
  #15 (permalink)
Old 01 Jun 2004, 03:19 pm
Mike-in-Orange Mike-in-Orange is offline
quote:sakigt
USA
Posted - 05/31/2004 : 8:48:07 PM
Id like to know what kind of trannies you guys have. Mike's 89mph compared with macster's 91mph...could that be due to autsostick vs auto?
I was the only one with the plain jane auto - all others had autostick.
quote:The night I ran my 14.6 I ran a 15.51, 15.9, 14.9, 14.7 then finally the 14.6....
Wow, you had over a full second time difference from worst to best runs!? What do you attribute that to? I figured we all had better times on our second runs because it was noticeably cooler out for run 2. But 1.3 seconds......that's huge.
One other thing regarding my own times....I'm really starting to think that my heavy (23lbs each) aftermarket wheels are, at least to a degree, holding me back. Any thoughts?
  #16 (permalink)
Old 01 Jun 2004, 03:52 pm
tezz tezz is offline
Guess I'm last to log in with results...
Had fun meeting the guys.
My reaction times just plain sucked. It's only been 30 years since I last did this and running stock tires that spun like crazy didn't help.Enough excuses, my times:
run1
rt 1.36
60 2.36
1/8 9.6@ 72mph
1/4 15.06@90 mph
run2 (grudge race w/Macster)
rt 1.54
60 2.23
1/8 9.4@73.1
1/4 14.74@91.75mph
I'm anxious to try again - with stickier/fatter tires. I might have done better letting some air out of the stockers, but the compound is so hard it might not have mattered anyway.
I do run Adam's UCP, but use the X brand CAI with a K & N in the stock box.
tezz
Black 03 PT/GT - Autostick,Stage 1, Mopar BOV, DC rear sway, K&N filter/white baffle out, Magnaflow cat back, Eibach springs, billet strut bar, AMX CAI,3bagged UCP, Euro tail lenses, Revell shifter, misc. do-dads
  #17 (permalink)
Old 01 Jun 2004, 05:16 pm
JPMS GT JPMS GT is offline
I'm in next time! Adam told me you were going when he installed my ucp, but I told my wife we would go to Big Bear for the week-end. The tail light fit fine Mike but I still need the bodywork done.
Inferno Red \'04 GT Autostick, Stage I, BTG exhaust, Airforce One intake, V.A.K. Candy Red upper charge pipe, BTG strut bar,Hyperground, chrome side spears and grill accents.
  #18 (permalink)
Old 01 Jun 2004, 09:01 pm
026TB4U 026TB4U is offline
Send a message via AIM to 026TB4U
what is adams ucp i have been sort of reading the posts a little and also has anyone tried alcohol injection i have seen drastic increases on my buddies dyno runs with it. by the way my best 1/4 mile time is now 12sec at 118 mph.[8)]
stage 1,manual bleed valve(18psi), k&n drop in , silencer removed, mopar bov and oh yeah its totalled now, waaaah
  #19 (permalink)
Old 01 Jun 2004, 09:23 pm
Cal Cruzer Cal Cruzer is offline
Adam makes a metal upper charge pipe (runs from the IC to the T_body) that replaces the stock rubgber one. Rubber piping has a tendency to ballon, especially under heat and higher boost conditions, and this will effect boost levels. The solid metal piping fixes this.
  #20 (permalink)
Old 02 Jun 2004, 03:31 am
Glad to help out with the tail lights....sorry you needed them in the first place! Would love to have you join us next month - getting you and Adam in on the fun would give us a half dozen PT's at the strip....that should make an impression!
vB code is On
*UPDATED* California Speedway January 22, 2005 PTGT_Boy Western PT Forum 0 23 Dec 2004 04:26 am
California Speedway September 18th PTGT_Boy Western PT Forum 2 17 Sep 2004 05:10 pm
California Speedway August 21st PTGT_Boy Western PT Forum 3 20 Aug 2004 05:56 pm
California Speedway July 31st PTGT_Boy Western PT Forum 0 29 Jul 2004 09:24 pm
July 17th California Speedway rice_killing_GT Western PT Forum 3 01 Jul 2004 04:39 pm
  Myspace Proxy | Credit Card | Adverse Credit Remortgage | Tax | Best Credit Cards
