| Site Home | Forum Home | Photo Gallery | PT Events | PT Videos | Car Videos |
Deen
GT, 5-Spd, K&N filter, Stage I, AGP 3147 Big Turbo, DTEC Fuel Kit, Tial WGA, Greddy Profec EBC, DCR 55mm TB, 05 Plastic Manifold, 180 Deg. Stat, CCA FMIC, AMX hard-pipes, Water-Injection, STS shifter, Needswings 3\" DP w/dump and Borla Cat-back, BG Drop Springs, Eibach Sway Bars, Panther alloys & Eagle F1 Max-Performance Tires. Best run to date...12.93 @113.45MPH. 77 Blown Vette-runs 10\'s @ 136 MPH. |
Mike-in-Orange,
SSR Competition wheels are 13.2 lbs each for the 17" size. But, they are $355 a wheel (Tire Rack)... Scott
\"If you choose not to decide, you still have made a choice.\" |
[quote]quote:Originally posted by hyracer
In order for a PTGT weighting 3443 lbs to run a 12.9 ET in the 1/4 mile, it requires 412.1 HP at the flywheel or 317 HP at the wheels. So did you run that time in a PT or some other vehicle? m~
Don\'t help me Help the bear Patriot Blue PTGT, Stage1, K&N Typhoon, 2.5\" Cat back exhaust, Sun Hyperground, Sun HOT INZAMA Hyper Voltage system, Adams Uppipe |
Before you hit on the kid from Red Deer remember what I said; if you need cold air you have a choice; 1) move the passenger side AC pipe to the intake or, 2) move to Red Deer ( Canada )! Remember gentlemen; you want to be in the 12's, seconds, not degrees! [^]
Jn
Inferno Red \'04 GT Autostick, Stage I, BTG exhaust, Airforce One intake, V.A.K. Candy Red upper charge pipe, BTG strut bar,Hyperground, chrome side spears and grill accents.
However no matter what kind of deer it is, you gotta have the HP and torque. So what kind of set-up does he have? m~
All of your passes proves my "PCM Learning Conspiracy theory" The first and sometimes seccond pass on the car will allway be crappy. The PCM has adjusted to normal driving, after a few passes, the PCM will be working better and the engine will increase performance (to a point).
Now I need to check the "Reseting your PC will increse HP" theory. I want to test the car first right out of the street, then a second run just like it is, for the third run, Reset the PCM and do a fourth run for consistency. My theory, by just doing this, the car will show a big HP and torque gain in the last two runs. Proving the "Learning PCM" theory. Ian
Hmm In order to do that and to control the conditions as much as possible, the temp/time of day has to be relativity the same. The time between runs has to be the similar. The weight of the car and the driver (ß-- no pizza etc) has to be the close. When I did my consecutive runs the car dropped down (lets say a max of -.3) and then leveled off in performance. BTW, that was one of the reasons I put the times of the runs in my spreadsheets. I also need to add a temp and mod column to spread sheet. Finally some mods will only help the 1/8 mile times while others will only help the 1/4 mile times. But you are on to something. m~
I am 99% sure that if you do the passes consecutively, It will show.
I have noticed this fenomenon on the road. the car could feel slugish but after a few accelerations it comes back to life! there is a big HP increase from the PCM from 14.78 (205HP According to a HP Calculator using a weight of 3300LBS) and 14.20 (230HP using the same weight). I have no doubt that the PC is to blame. 25 HP increase, The PCM is defeanetly changing from street to Strip with every pass. Maybe the dyno thing will be a little harder to see because what you have stated, but the PCM is dynamic and will compensate or reduce depending on what it reads. We have proven already that altitude doesn't affect the "factory" performance of the car. The times are great! and best of all Realistic. A year has passed since we started to study the PCM and the internals of this engine and we still have a lot to learn. I will losely echo the words of a fellow Driver from the forum (which I havn't heard from latetly on the performance side) DALITE: "It will be a hole lot simpler if DC would release the PCM programing codes to the public". He was the key person in sheding light on the PCM mistery. It is where the HP scavenging game ends. Just two cents.
Hopefully the next time I go out I'll get more passes.
R_K_GT \'03 Electric Blue GT, silencers removed, K&N intake, Blanes Hood Struts, Emblems removed from rear hatch, Stage 1, Mopar BOV, Eibach springs, 18x8 Mille Miglia EV-R on 225/40/18 BFG g-Force T/A KDW 2, Eibach sway kit F&R, BTG Strut Bar, Chrome fuel door, custom 3\" cat-back exhaust with Magnaflow High-flow muffler, Blitz Dual Turbo Timer, Autometer Triple gauge pod, Autometer Ultra-lite with boost/vac, oil press and water temp gauges, Turbochargers.com wastegate, turboxs DSBC, Adams UCP, Dynoworks motor mounts with more to come..... |
[quote]Originally posted by Ian-PT-GT
I am 99% sure that if you do the passes consecutively, It will show. [quote] I did the consective runs. They are the green text items on that spreadsheet that I sent you. m~
| *UPDATED* California Speedway January 22, 2005 | PTGT_Boy | Western PT Forum | 0 | 23 Dec 2004 04:26 am |
| California Speedway September 18th | PTGT_Boy | Western PT Forum | 2 | 17 Sep 2004 05:10 pm |
| California Speedway August 21st | PTGT_Boy | Western PT Forum | 3 | 20 Aug 2004 05:56 pm |
| California Speedway July 31st | PTGT_Boy | Western PT Forum | 0 | 29 Jul 2004 09:24 pm |
| July 17th California Speedway | rice_killing_GT | Western PT Forum | 3 | 01 Jul 2004 04:39 pm |
