mid- motor mount bolt
Like Tree9Likes
Old 27 Mar 2016, 09:05 am
Default mid- motor mount bolt
Luv my lil turbo, but it suddenly developed a front shuddering on acceleration. Quickly found the upper mount needed replacing, but a short test drive found the problem persisted. Went to check that damn mid-engine mount and the torx bolt fell into my hand. The dealership said 46 were on backorder and I needed to buy a minimum of 4. Went online to find tha M14-1.75x85 case hardened torx type bolt and found nothing, needed the Vin to find the exact bolt sizing since apparently used 16 different bolts. Has anyone got one they are willing to sell at premium or a source? Dealer also told me the backorder would be at least a month out.
Old 27 Mar 2016, 02:32 pm
2step's Avatar
Default Re: mid- motor mount bolt
A fellow I know on another Cruiser forum drilled and tapped that center mount for a bigger, thicker bolt. If I recall, he may have broken the "bigger" bolt and drilled and tapped again for the next size larger.
If you pin down the size of the stock bolt, you should be able to buy a replacement from a company such as Fastenal right off the 'net fairly quickly.
willy13 likes this.
Old 27 Mar 2016, 04:05 pm
I have read something to what you mentioned can't remember where?
That was a procedure that I think ED Peters once posted or told someone ( I think an employee at Modern Performance that once owned a PT?) many many moons ago and they past it on..
Some claimed that a larger diameter was needed for strength on the lower torque strut? This would make absolutely no sense consider how the engine force and rotation under load is applied to that mount and the fasteners.. but hey what do I know ...right? lol
The bolts are common size anyway, not sure why there is a problem finding replacements at a well stocked hardware store??
willy13 likes this.
_PTGT03's Avatar
right on guys. mine started to strip its threads and wouldn't meet the specified torque tolerance. i'm about at 2/3 of its specific torque rating right now. i should have it replaced sometime soon.
Old 28 Mar 2016, 07:33 am
Handy_Cruiser's Avatar
Modern Performance makes I kit that has harder motor mount bolts. You can also get that harder center bolt from a fastener shop. Look for a bolt with a metric hardness of 12.9. Take your old bolt with you to match up the length and threads.
Also, you can always replace the mount plate that goes on the engine if the one you have is stripped out. Salvage yards are full of them.
Old 29 Mar 2016, 07:48 am
Thanks to 2step and nitro for such rapid response. Problem I seem to be is finding the torx head. Am going to try Fast after leaving this post. Hardware stores have metrics but all are hex heads. Am going to try to drill with 135 split pt.+ use a #5 extractor so will loosen mount bolts to give me a little xtra wiggle room for error of alignment backing out broken piece.
Old 29 Mar 2016, 09:57 am
2step's Avatar
As I recall it was GT Bruiser posting a couple years ago on the Crew forum.
I actually didn't realize it was a Torx. I've never broken one of those. That makes it somewhat harder to find but not impossible nor having to wait for a back order. And of course, if you step up in size you probably have to buy a tap, too.
Old 29 Mar 2016, 10:04 am
Fk5 Fk5 is offline
I think I missing something. If you are changing the bolt, why does it have to be a Torx head? As long as the thread length and pitch is okay, what would the issue be with using a different bolt head?
Handy_Cruiser likes this.
2003 GT 5 speed
162,000 miles
Old 29 Mar 2016, 10:05 am
The head of the original torx bolt is countersunk into the motor mount. But by adding a shim that will fit in the recess on the motor mount, it may be feasible to use a hex bolt. You would just need to make sure the head of the hex bolt will not hit the chassis when the engine moves. But that really doesn't look like it would be a problem. At worst you might have to slightly increase the size of the assess hole with a hole saw.
Old 29 Mar 2016, 10:45 am
Hey how about just getting the correct fastener on this one...
Have you dealer do a "dealer search" for the part. I am sure a dealership somewhere has it and can express mail it to you.
I am starting to worry about some of the recommended things to do in this thread ....
Missing upper motor mount bolt Mbreen General PT Cruiser Discussions 12 17 Mar 2015 07:26 am
Broken motor mount bolt madeupofwires General PT Cruiser Discussions 1 24 Jun 2014 03:58 pm
Sheared Off Motor Mount Bolt - 2001 PT SteveG22 Tech & Performance Forum 7 19 Feb 2014 06:04 am
Lower motor mount bolt sheered off invidious Tech & Performance Forum 6 16 Sep 2013 05:08 pm
Removal of Snapped off Main Motor Mount Bolt - SUCCESSFUL! desarae77 Tech & Performance Forum 15 29 Jul 2013 07:56 am
