Turbo leak tester
  • 1 Post By myckee
Old 09 Apr 2016, 04:46 am
Default Turbo leak tester
Did somebody used this tools for see if there is any leak on the turbo ?
If not do you think it ll work ?
PT CRUISER 2L 2000 STARTECH
PT CRUISER 2,4L GT 2004
CHRYSLER VOYAGER 3.3 1993
CHRYSLER VOYAGER 3.8 AWD 1997
CHRYSLER VOYAGER 2.5 CRD 2003
Old 09 Apr 2016, 07:47 am
Default Re: Turbo leak tester
It looks like it will work but it looks expensive to use only once or twice. I have seen some Do It Yourself homemade versions that will do a similar job and not cost very much. I saw one where the guy used some PVC pipe and PVC pipe ends. Then he drilled a hole in the end and put a fitting, like a tire valve stem there. Then you can simply use a car tire pump to put a 20 psi or so into the system to see if it holds, and also to locate any leaks.
I am going to assemble a tool like this. It should be really cheap to make.
LionPT likes this.
Water Leak on Turbo chuzz General Turbo Discussions 10 18 Sep 2015 01:46 pm
pt turbo vacuum leak cruiserbruiser05 Tech & Performance Forum 12 24 Mar 2014 10:07 pm
Block Tester, blown head gasket lmarkie74 Tech & Performance Forum 8 15 Feb 2014 10:55 am
Water leak Under turbo 03turbo Tech & Performance Forum 14 11 Feb 2013 09:24 pm
Stock Turbo, wideband, and leak tester Kawizx9r Classifieds: For Sale/Trade 1 13 Jun 2011 01:23 pm
