New (to me) 2007 PT no shift from 2nd
Old 11 Apr 2016, 07:51 am
Default New (to me) 2007 PT no shift from 2nd
I recently (3 weeks) purchased this 2007 touring turbo, used, with 117k on the clock. Took my OBD scantool with me when I test drove it. No codes. Ran great. A few clunks from the suspension which have since been remedied. Now, I'm getting a no shift from second. Codes were P0700 and P0884. I've read various threads on several forums (here included) suggesting a multitude of possible causes. I have replaced both the input and output speed sensors, cleaned the terminals from the solenoid pack, cleaned the battery terminals as well as replacing the negative terminal, cleaned and inspected the TIPM for any obvious signs of corrosion, cleaned the trans pigtail at the battery box, all to no avail. I will say that each time I disconnected the battery, it would shift and run fine for one "cycle" but would fault on the next startup. Another symptom was in the dash; when it faulted all the "gears" (P, N, R, D) were sleceted (circled) on the led display. I'll attempt to take it to the dealer soon, however, before I start throwing more money at it, does aneone have any more suggestions? Thanks in advance.
Old 11 Apr 2016, 08:21 am
Default Re: New (to me) 2007 PT no shift from 2nd
I would suggest checking the Transmission Control Module power supply circuit to direct battery for broken or high resistance wire.
If that is okay then check the continuity from the Transmission Control Module power supply circuit to the ignition switch.
If that is okay check to see if the Transmission Control Module power ground circuit is open or the connector is loose.
If that is okay check the Transmission Control Module.
Old 12 Apr 2016, 12:47 pm
Thanks for the quick response. This seems to be a common issue with these, no? Just typing in "Chrysler P0700 P0882" brought up a plethora of PT cruiser questions. Was this as big an issue on other similar applications? Neon, Caliber, Stratus, etc.?
2007 Pt Cruiser 2.4 Limited Turbo Shift Cable related? cataclyzmic Tech & Performance Forum 1 16 Jun 2016 04:32 am
Won't shift.....sometimes dragginbutt Tech & Performance Forum 2 18 Jul 2014 11:40 am
B&M Shift Plus 04PurplePT Tech & Performance Forum 2 03 May 2010 08:58 pm
Changed Shift solenoid but still wont shift hawaiian General PT Cruiser Discussions 1 19 Oct 2009 07:32 am
Shift Kit Bugeye Tech & Performance Forum 2 10 Nov 2002 11:58 am
