code p0420
  • 1 Post By aarOneShot
Old 29 Apr 2016, 07:07 am
aarOneShot's Avatar
Default code p0420
Cat system efficiency below threshold bank1
i replace cat with downpipe. error code on o2 sensor.
does anyone have thoughts. does it need to be remaped
2006 GT 2.4HO Turbo
Old 03 May 2016, 06:51 am
aarOneShot's Avatar
Default Re: code p0420
Sorry...can anyone help me with this please.
looking for help...
2006 GT 2.4HO Turbo
Old 03 May 2016, 07:06 am
Where did you get the 02 sensor? If it's not an OEM Mopar brand one, I'd recommend getting one. Aftermarket sensors are not always up to snuff.
Old 03 May 2016, 07:24 am
Fk5 Fk5 is offline
I don't think it is the sensor. If I read his post correctly, he did some exhaust mods. This often causes O2 codes because either the sensor doesn't reach temp fast enough or the "normal" readings for the O2 sensor changed. He also may have pulled the cat.
There are plenty of ways around it, most involve wiring or computer flashes. I have actually seen one thing where they have a "mini-cat" that screws into the O2 bung and then the sensor screws into that to replicate a stock exhaust. I have no idea of the best work around. Maybe Nitro or one of the mod guys does.
2003 GT 5 speed
162,000 miles
Old 03 May 2016, 07:33 pm
aarOneShot's Avatar
yes i pulled the cat.replaced with downpipe.
did not change o2 sensor
thanks
2006 GT 2.4HO Turbo
Old 13 May 2016, 06:40 am
aarOneShot's Avatar
thanks to everyone that helped me out.
now the part i got is a 90 Degree Angled O2 Check Engine Light CEL Fix Oxygen Spacer Exhaust Extension. made by CNT®. my light has stayed off for a week now.
anyone running a downpipe with no cat, this is the part you need.
Fk5 likes this.
2006 GT 2.4HO Turbo
p0420 code, trouble starting, low coolant and need transmission flush - Sell or Keep? funkyfred General PT Cruiser Discussions 4 15 Apr 2016 05:01 pm
Code P0420 - Cat Efficiency lytebulb Tech & Performance Forum 2 08 Jan 2016 08:09 am
P0420 Code Advice Needed falconut Tech & Performance Forum 45 10 Oct 2015 08:46 pm
P0420 code Converter Code? 2008/110,000 miles Sarasmiles Tech & Performance Forum 8 28 Mar 2014 07:08 pm
P0420 code, Much needed help!! Cruisergirl1 General PT Cruiser Discussions 1 15 Oct 2012 04:45 pm
